Go Back   EcoModder Forum > Classifieds > For Sale
Old 10-29-2013, 07:31 PM   #1 (permalink)
Auto Insight 144k $2,400 New Jersey
2001 Honda Insight Hatchback with A/C
Doing my usual check for deals. This was the lowest one i found with the best value. Some cosmetic defects, but overall very nice looking. Most likely hiding an IMA light. I drive really good in my automatic and get consistent 70mpg+ tanks from late spring to mid fall.
I try to be helpful. I'm not an expert.
Old 10-30-2013, 09:30 PM   #2 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
A dealer ad in the "By Owner" section, that's always a good sign that the guy's not a kink ha ha. And I've always wanted a car that ran "smoth". The CVT Insights didn't have lean burn, so keep that in mind, and from the looks of that place, if you do go look at it, do yourself a favor and run a carproof or some other history check on it. And make sure the IMA light comes on on the dashboard when you first turn the key, it should do a self check along with all the other dash lights before start up. If it doesn't then there is something funky going on to cover up a dead IMA battery. Good luck.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
