Old 12-30-2008, 04:04 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
How can I achieve max MPG with a little help
Strange question for an even stranger purpose.
If I wanted to draft behind a vehicle for maximum MPG gains under controlled conditions what would be the ideal shape of the object in front of my vehicle so I can draft it at a safe distance?
I hope the question is not to confusing ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 12-30-2008, 05:36 PM   #2 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Busses work well for me.
Old 12-30-2008, 06:46 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Some show (might've been mythbusters) built an extension on the back of a trailer that stuck out and and empty, then they pulled a honda insight up in the back inside of the little box. I figure that's pretty good.
Old 12-30-2008, 06:55 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yeah, if you can fit somewhere that won't interfere w/the wake of the vehicle in front of you, you're essentially in a vacuum.... most efficient place to operate would be in a vacuum where the engine could still get as much air as it needs without sac'ing VE.
Old 12-30-2008, 10:04 PM   #5 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
A flying brick wall with a Kammback that fit around your car would most likely be best?
Old 12-30-2008, 11:53 PM   #6 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Hahah that just sounds funny ... Yeah i get 2,000mpg because I follow an ecomodder kammbacked flying brick ... hahahah
Old 12-31-2008, 09:35 AM   #7 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Something with a low bottom edge. Semi trucks are bad for this. Tour buses are better.
I agree about the Kammback part, too. Basically, build a box and drive your car inside it.
Old 01-01-2009, 08:09 AM   #8 (permalink)
blueflame's Avatar
The bicycle land speed record guys ride almost inside a truck.
Here's the video :
The low bottom edge is right on the ground, and the lead vehicle upper edge is upward.
Old 01-02-2009, 03:42 PM   #9 (permalink)
So the questions begs, would it be considered cheating to attempt and beat that mpg record by using a pace car similar to the one bicyclists use? You technically are not modifying the car attempting the record, just giving it the best shot.
Old 01-02-2009, 08:15 PM   #10 (permalink)
Is it cheating using steroids? I mean, everybody supposedly uses them and they are natural?!
NOOOOO
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The 66.6 mpg challenge groar Success Stories 3 01-04-2009 09:05 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
MetroMPG.com mailbag: is lowest RPM really best for max MPG with big displacement? MetroMPG Hypermiling / EcoDriver's Ed 20 01-06-2008 01:00 PM
