Old 11-29-2017, 01:24 AM   #1 (permalink)
coast down idle?
Ok having a senior moment. Is it called a coast down idle when you coast with clutch in but engine slowly drops idle? OBD I system, can this be changed? Even fully warmed up idle only drops to about 850 where if not rolling and after about 30 seconds it will drop to about 600. I know it is there for ease in engaging the clutch again but I can handle that.
Old 11-30-2017, 04:29 AM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
If it only idles high when moving, all you need to do is make the ECU think the car isn't moving.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 11-30-2017, 07:48 AM   #3 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Indeed, Natalya has a module for the Insight which can, on demand, feed the ECU a ~1mph signal, which could in theory allow for low idle while coasting. Our cars shut the engines off entirely in those cases though.
