Old 03-09-2009, 08:40 PM   #1 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
AutoSpeed Article: Low Drag Car Aerodynamics
AutoSpeed: Low Drag Car Aerodynamics
Originally appeared March 8, 2008.
Nice introduction to the aerodynamics of automobiles.
When a car moves, air is deflected above, below and around it. The point at which the air splits to pass above or below the car (termed the stagnation point) is important in deciding how slippery the car will be. The lower the stagnation point, the better, because then less air runs into the (usually) rough underside of the car. However, unless the car has a front spoiler extending almost to the ground, air will pass under the car. This has caused some manufacturers to start adopting low drag undersides for their cars. There is also another reason for entraining this air into a smooth flow – creating less lift, which we’ll get to in a moment.
Even quite minor changes in rear hatch angle can cause major changes in drag. Tests carried out by Volkswagen have shown that the Cd of the car can vary from 0.34 to 0.44 as a result of slight alterations to the rear hatch angle. At one angle (30 degrees to the horizontal in this case) the airflow separation point jumped back and forth from the end of the roof to the bottom of the hatch, depending upon the curvature at the rear edge of the roof. It was this 30 degree rear hatch angle that produced the highest Cd value. This sort of substantial change in the car’s drag coefficient will have a large influence on the car’s top speed and fuel consumption. In some cars even a 10 per cent reduction in drag will decrease open road fuel consumption by 5 per cent.
The current automotive fashion is for manufacturers to pay only lip service to aerodynamics. In fact, there has been little improvement in CdA figures in the last decade. However, at highway speeds, most of the power being developed by the engine is being used to push air out of the way. For cars of the future to improve their open road fuel consumption, CdA figures will have to once again fall: it is simply a physical requirement of efficient car design.
Old 03-09-2009, 11:02 PM   #2 (permalink)
Hi,
Do you have a link to the entire article, please?
Old 03-10-2009, 01:26 AM   #3 (permalink)
Ops. Added to first line of initial post.
Old 03-10-2009, 10:50 AM   #4 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I wrote to Julian, chiding him for his usage of "laminar" and got this back:
(that one was first published about 8years ago) , I have used ‘attached’. Eg I have done this in Browser Warning.
The newer article seems more comprehensive and correct, just leaving out internal flow. I'm not sure if the recommendation to reduce induced drag as a second priority can be done while saving drag if we use wings to fix a shape instead of re-shaping it.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 20 03-18-2014 05:31 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Article: Quebec may ban "zoom zoom" car ads MetroMPG General Efficiency Discussion 4 05-26-2010 10:22 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
