Old 08-06-2008, 07:49 AM   #11 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Generally, it's easy to screw things up when you don't have proper feedback.
You really need to have a wideband sensor to monitor what you're doing. You cannot tune appropriately with a binary sensor.
You should also only lean it out at low loads. 80 mph isn't exactly what I would call a low load on a car with an average CdA.
And finally, if your mileage is crappy, you are probably running too lean.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 08-12-2008, 11:22 AM   #12 (permalink)
chilimac02's Avatar
I'm VERY interested in the how's of leaning A/F mixture. I have a scangauge II, will it display A/F mixture? I've been noting when closed loop vs. open loop occurs. My car stays in closed loop up to about 90 Load, unless the throttle position is over about 75%.
The article you mentioned discusses cruising in open loop... My car doesn't do this. Does that mean that I cannot modify the A/F mixture at cruising speeds (55mph)?
Old 08-13-2008, 06:55 AM   #13 (permalink)
Hi Julian and Welcome from me as well.
Autospeed is frequently mentioned here and many people benefit from the knowledge posted there.
Cheers , Pete.
Old 08-13-2008, 12:33 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
chilimac02 -
You may be able to display the voltage of the 02 sensor using the X-Gauge option, but you will need to know the access code for it. However, I have not seen a specific example of anyone doing this, and the 02 sensors flips back and forth so much that you would need a refresh rate that is faster than the ScanGauge's "4 digital gauge" option. Sooooo, it may not be practical.
CarloSW2
American Solar Energy Society
Old 08-13-2008, 01:07 PM   #15 (permalink)
Originally Posted by cfg83 View Post
chilimac02 -
CarloSW2
I did it 3 months ago.
Old 08-13-2008, 01:12 PM   #16 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
tasdrouille -
Originally Posted by tasdrouille View Post
Mea Culpa! I missed that
CarloSW2
Old 08-13-2008, 01:24 PM   #17 (permalink)
ALS
The fuel being injected in to the cylinder actually cools the piston and cylinder wall from the last power stroke. That is why people who run too lean will get a damaged piston, burnt valves or say their exhaust manifold is glowing cheery red. Many manufacturers are now install piston oil squirters. These oil squirters spray oil on to the underside of the piston to cool it down.
Old 08-13-2008, 02:40 PM   #18 (permalink)
Partly true. The fuel indeed helps with cooling the walls, but temperature peaks at a bit leaner than stoich, and tapers on both sides. Running very lean or very rich lowers temperature, running a bit lean leads highest temps.
See the graph in this document.
The nasty stuff happens simply because you're running too hot, not as a direct cause of running too lean. You might say you're running too lean for for the temperature/load. As you said a solution to run cooler is to run richer. But if the engine could run very lean and without detonation, temps would be down. Since most of the time when you need to run cooler you also want to make big power, you go rich as going very lean leads to a reduction in power (and detonation).
Diesel engines run very lean and are cool. As you richer a diesel you'll see the EGT go up. If you would richen it past stoich (similar to a gasser stoich), the EGT would go down again, but it would be hurling out thick black smoke.
Old 08-13-2008, 04:52 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
tasdrouille -
The nasty stuff happens simply because you're running too hot, not as a direct cause of running too lean. As you said solution to run cooler is to run richer. But if the engine could run very lean, temps would be down. Since most of the time when you need to run cooler you also want to make big power, you go rich as going very lean leads to a reduction in power.
This is what I have read, but I am unable to describe it this well.
CarloSW2
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
lean burn rules~! coolwHip Introductions 42 10-01-2011 05:42 AM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 12:42 AM
Running "Lean" with a Resistor Divider on the Air Temp Sensor steensn EcoModding Central 22 05-16-2008 09:11 AM
