Old 06-01-2014, 10:23 PM   #1 (permalink)
The Lisle Luddite Lodge
The Honda - '91 Honda Civic LX
90 day: 34.67 mpg (US)
The Honda-1991 LX Sedan
Hi all,
This will be the main thread for our new project. We work in cycles so there will be periods of activity interspersed with silence. I expect it will take at least couple years to complete the list of desired modifications in between the rest of life.
We are putting together a vehicle we can afford to drive on trips. I have done all kinds of aero-mods to my vehicles over the years but I have never planned such mods in advance. In the past it has always been a case of mitigating an obvious deficiency or two on a daily ride or work vehicle.
This is the first time either of us have purchased a vehicle specifically for this purpose.
We looked concertedly for almost a year and intermittently for closer to two years.
We finally gave up looking for a manual transmission and purchased a 1991 Civic LX automatic that only had 118k original miles and was fairly well maintained mechanically. There was some severe rust around the rear wheel wells and rocker panels but the main pan and structural elements are in great condition. The original factory extended warranty maintenance records stamped right in the original manual from a local dealer that still exists were buried in the glove box. Only the last 3 years are not complete and we have many of those too.
We did a fairly extensive list of maintenance and stabilization procedures to get the car to a good point for the coming modifications. (All 100k maintenance items, new ignition components, timing belt, water pump, new rear brakes, removed those annoying metal weather seals from the back brakes that always rust, get bent and drag, plus checking condition and lubricity of axle bearings) We sealed the holes, stopped and stabilized the rust. Most of those areas will be covered by the coming mods so I will rebuild the rear wheel wells at that time.
Since we are doing this with long trips in mind we will not be doing anything to significantly reduce visibility, handling or safety.
That means we will not be deleting windshield wipers, experimenting with LED lighting, covering directionals or marker lights or things like that. The side view mirrors need to stay. I have been driving vans and work trucks for so long my brain does not even notice a rear view mirror. We will probably need them with the Kammback anyway,
It also means that we actually added to the weight of the car. We replaced the mini-spare with a full size spare. Added about 30 lbs of tools and emergency supplies not counting water.
It will always have two adults, running at about 340 lbs plus miscellaneous materials related to whatever we are dong. We are talking around 400 lb total payload back and forth to town and as much as 600 lbs on trips.
So far I have only done a mileage calculation on the first half a tank. That came out to 35mpg. I can not help but get my hopes up. I hope that ends up being a real number. We have a long drive on Tuesday that should get us a full tank calculation.
Because of the EPA rating on this car my initial goal was to shoot for 40mpg. If the 35 mpg holds up I will think about altering that goal.
1991 Civic LX
Operator software optimized for efficiency
Current modifications:
Vacuum gauge
Deleted rear mud flaps
Planned modifications:
Manual torque converter lock up
Full gauges (only has factory temp gauge)
MpGuino
Large front air dam (covering front grill)
Skirts
Rear Wheel enclosure
Partial rear pan
Kammback
Old 06-01-2014, 11:52 PM   #2 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Welcome! Start a fuel log here at EM? You could add a partial or full grill block to that list, with shutters and the ability to open them within the car. Mooncaps on the wheels? Also, take off the power steering belt if you have PS. You will be amazed how unimportant PS is in our little lightweight cars, especially with your trucking experience.
Instead of deleting rear mudflaps, like I did, use them as the basis for rear tire strakes.
Old 06-06-2014, 01:41 PM   #3 (permalink)
I already started a fuel log
We went on a long day trip on Tuesday.
I logged just over 40mpg.
30% NY Thruway 65-70mph
60% 2 lane 55-65mph
10% city stop and go.
I am amazed at the results I am getting by just driving conservatively.
This trip allowed me to tune into the transmission and it is pretty impressive. Snappy shifts, very predictable. Once it is warmed up the lock up will engage reliably at 45 mph and I can hold it pretty well even up moderate hills.
1991 Civic LX
Vacuum gauge
MpGuino
Skirts
Partial rear pan
Kammback
Old 06-06-2014, 02:14 PM   #4 (permalink)
Cyborg ECU
Transmission
Glad you are enjoying the transmission feel. If you get into big mods eventually, you might consider a transmission swap to a Civic HF trans of the same year or generation. That would bring your freeway rpms down and increase fuel economy. See the gearing differences here: http://ecomodder.com/forum/showthrea...ios-26279.html
James
Old 06-07-2014, 12:32 AM   #5 (permalink)
What have you used to seal the rust holes?
Old 06-07-2014, 11:40 AM   #6 (permalink)
The holes are sealed with a foam pak, the same stuff we use to seal holes around doors and windows only in a larger, 2 component package.
First I used a product called "Chassis Saver" it is the best stuff I have found to stop and convert the rust since the EPA regs ruined "Extend". Chassis saver is not as good as the original Extend but is the best thing I can find here in NY and it is waaayyy better than the Extend they sell now.
I did a considerable amount of prep to uncover all the hidden rust bubbles... Then I did a few coats of the chassis saver, multiple thin coats until no more rust comes through is the best procedure. Follow the instructions meticulously and it works great. The black spots on the body are the spots I applied chassis saver. The rust marks are rust stains on the paint.
I put in a couple temperary stops to keep the foam from going where I did not want it to go and filled the associated cavity and surrounding spaces with foam.
I then trimmed the foam to shape, I did a small fiberglass layup over the foam for strength, followed with a little bondo filler for the worst diviots. Spray can of self etching primer and generic car store paint.
As long as you are careful to find and convert all the rust before encapsulation this sort of repair has lasted me many years in the past. All subsequent rust that appears must be addressed quickly to maintain the itegrity of the body of the vehicle.
If we do that from the start then we get many more years out of our cars here in NY salt counrty.
1991 Civic LX
Vacuum gauge
MpGuino
Skirts
Partial rear pan
Kammback
The Following User Says Thank You to Luddite Lodge For This Useful Post:
The donkey CRX (06-07-2014)
Old 06-07-2014, 09:14 PM   #7 (permalink)
That's for sure a labor-intensive project. Using foam in vehicle repairs is not so usual in my country, but patching with fiberglass is not uncommon.
Old 06-08-2014, 11:48 AM   #8 (permalink)
It has been somewhat labor intensive but I am mostly retired so we have more time than money.
Everything I do goes through an intensive cost benifiet analysis.
So far we are into this car for only $1100. Pretty good for how well it is performing.
That foam techinique has been around here for many years, I think it is actually required for rust hole repairs in Pennsylvania.
They use a lot of salt on the roads in the winter and it rots out the thin metal in the new cars pretty quickly. It is as bad and maybe worse that living near the ocean
1991 Civic LX
Vacuum gauge
MpGuino
Skirts
Partial rear pan
Kammback
Old 06-09-2014, 12:20 AM   #9 (permalink)
I lived in an island for some 12 years and rust issues related to the salt mist were not uncommon, but probably using salt on the roads has worse issues...
Old 06-09-2014, 12:23 AM   #10 (permalink)
Cyborg ECU
I grew up in the road salt regions of the USA and now live in a year-round warm climate by the ocean. There is no comparison: road salt eats cars and the ocean has nearly no effect. Classic cars are everywhere out here because of it. We have it easy in Southern Cali (until "the big one" hits, knock on wood).
