Old 07-15-2009, 06:28 PM   #1 (permalink)
chipsndukes's Avatar
chipsndukes - '96 Toyota Tacoma
90 day: 31.37 mpg (US)
Backfire
Well, I just introduced myself, in the other section.
I am not new to ecomodding, I have been "lurking" for a while and trying my hand at saving fuel.
I wanted to post, because something interesting happened yesterday:
I was driving out of a tight curve with the engine off, bumped it on a short straight and then shut down again for a tight left-hander.
It was uphill, and with someone behind me, I quick bumped the engine again...BOOM.
The person in front of me nearly stopped dead and I had to brake, the person behind me backed off. Nobody knew what happened, just that it was LOUD.
I know that it is possible to cause a backfire because of raw fuel in the exhaust system, but I thought that wouldn't happen, because when the ignition is turned off, the injectors close, right?
In a year, this has never happened to me, but I thought I would kindly ask for your comments!
Chipsndukes
Old 07-15-2009, 06:34 PM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 37.17 mpg (US)
In 1 1/2 years, this has never happened to me, but I thought I would kindly ask for your comments!
Chipsndukes
In a multi-cylinder engine, fuel can be injected into a cylinder prior to shut off, and the shut off happens prior to that same cylinder getting spark ignition. As a matter of fact, it's probably going to happen every single time, with 4 cylinders. Although it was probably the quick stop-start routine that allowed enough fuel to collect to cause the backfire.
I'd recommend installing a kill switch!
Old 07-15-2009, 06:40 PM   #3 (permalink)
Thank you very much Atomic.
How would the kill switch help to prevent a backfire?
Thanks!
Chipsndukes
Old 07-16-2009, 01:48 AM   #4 (permalink)
Thanks!
Chipsndukes
When you key off, the computer stops the spark and fuel simultaneously. With a kill switch, if wired properly, it kills just the injectors, keeping the spark going, igniting any left over fuel in the last few revolutions before the engine comes to a complete stop.
Old 07-17-2009, 03:23 PM   #5 (permalink)
OK, thank you very much, that makes sense.
Chipsndukes
