Old 10-24-2015, 03:39 PM   #1 (permalink)
Needs More Duct Tape
MPGomatic's Avatar
Slambo - '99 Honda Civic HX
90 day: 44.21 mpg (US)
A backroad lean burn ride in Slambo
I've cracked an indicated 60 MPG with Slambo on this route, but it didn't happen with the cameras running. Apologies for the fuzzy GoPro close ups on Dash Command (running on the $250 JVC head unit via AppLink) … I need a $$$ triangulated camera mount to avoid shake with a heavier camera.
https://www.youtube.com/embed/LS9ESYzDvRQ
(is there a way to embed videos in posts?)
The car's relatively quiet, other than some rattle off the shifter (need to take a look to see what's going on) and the whine from the input shaft bearing. The coroplast rear belly pan started squeaking after this was shot.
Gas was under $1.70 today at Costco, but I wasn't on that side of the river. Paid $1.90 at Valero.
Ain't Fuelin' - The Beater Build Show :
https://www.youtube.com/playlist?lis...R754kIg_V8Aahm
Old 10-24-2015, 04:30 PM   #2 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Watched the Stingray review last night. Low and slow (revs) makes for some good mpgs
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
The Following User Says Thank You to kafer65 For This Useful Post:
MPGomatic (10-24-2015)
Old 10-24-2015, 06:34 PM   #3 (permalink)
MPGomatic's Avatar
Holy cow, I miss the Stingray. So much more pleasant to drive that beast with cylinder deactivation turned off …
Old 10-24-2015, 07:15 PM   #4 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
If you just post the regular Youtube link without any code around it it'll automatically be embedded.
Camry Thread
E-Bike Thread
The Following User Says Thank You to vskid3 For This Useful Post:
Old 10-24-2015, 07:27 PM   #5 (permalink)
Thanks, I hadn't wondered how people post a video without embedding it, since I found out about the Quote button.
Old 10-24-2015, 07:55 PM   #6 (permalink)
MPGomatic's Avatar
D'oh! Thanks, Vskid3!
I've been cutting and pasting the wrong URL. (Choosing the share code, rather than the regular URL.)
Old 10-24-2015, 09:54 PM   #7 (permalink)
vskid3's Avatar
No problem! Love your videos.
Camry Thread
E-Bike Thread
Old 10-25-2015, 10:07 PM   #8 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Cool setup.
Staying off the throttle for long periods, with short bursts of high-RPM acceleration in 3rd, may not be the best way to maximize MPG. Here's my reasoning:
In order to travel at a given speed over a certain distance, you need to expend a certain amount of energy, and there's no way of getting around this. Reducing your speed reduces drag exponentially, for a linear increase in travel time, which is why slowing down (all else being equal) will improve your fuel economy.
The other factor you control is how you produce that power. Ideally, you'll want to produce the power needed for your chosen speed and distance as efficiently as possible, which is achieved at peak BSFC. Here's the chart for my engine:
Most engines will have peak economy at slightly higher RPM, but notice that as you rev it up, you get less out of your gasoline due to exponentially increasing friction inside the engine. For this engine, around 80% load at 2000 +/- 300RPM (ish) delivers the absolute best conversion of gasoline into forward motion. So, when driving, I'd want to shift to stay within those RPM boundaries. Unfortunately, 5th gear @ 80% load will inevitably bring me up past my desired cruising speed, so in real-world driving situations I would want to pulse at 80% load in whatever gear keeps me between 1700 and 2300RPM, and then shut the engine off until I slow back down to where when I drop it in gear, I'm at 1700RPM again.
I really like slow, rolling hills, because I can pulse up one side at 80% load, shut the engine off at the top, roll down the other side with zero parasitic loss from the engine spinning, and then begin my pulse again at the bottom.
Lean burn is wonderful because it allows you to produce less power at the same load/RPM, often allowing you to continuously run at 80%ish load without accelerating, or at least, extending the pulse so you don't have to repeat pulse and glide cycles as often.
Using this technique, I've had as much as 50mpg (city) out of a car rated for 26/30, and nearly 120mpg out of a car rated for 49/61.
It's difficult to average that over a tank when sharing that car with one's spouse, unfortunately.
MPGomatic (10-27-2015)
Old 10-25-2015, 11:52 PM   #9 (permalink)
...beats walking...
Spouses are usually NOT eco-friendly.
The Following User Says Thank You to gone-ot For This Useful Post:
