11-30-2022, 09:25 PM
home of the odd vehicles
Bathroom circuit with no load breaker off 600ohm resistance
I’m trying to troubleshoot what is going on
The ground fault to the bathroom has always been touchy
Went to replace it and now I find with the power disconnected 600ohms resistance between hot and neutral.
This means a .2 amp 24 watt load with nothing on
The bathroom circuit connects to an exterior light, the bathroom outlets, a fluorescent light in the ceiling and that is it.
Any ideas how I find the short?
11-30-2022, 11:17 PM
Don't know, but I'd pull the whole breaker out and measure again.
11-30-2022, 11:38 PM
I had the “breaker “ off and out of the circuit as a ground fault separates them on different wires load/line
I don’t think a ballast would have an “always on” segment
11-30-2022, 11:59 PM
I would suspect the light. Disconnect and see if your problem goes away. Remove the ballast and install LED tubes.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
12-01-2022, 02:18 AM
Too many cars
Are you sure there's nothing else on that circuit? Assuming the light switches are off (and wired correctly), the hot should only be connected to the switches, outlets, and breaker in the panel. So it's a GFCI outlet, but a regular breaker? Light-up switches or USB ports on the outlets? Meter working correctly?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
12-01-2022, 07:45 PM
It’s been extremely west/damp
I’m thinking the outdoor light outlet combo that is inexplicably on the circuit is to blame but I’m not sure how to break a hardwired thing I never use from the circuit.
I will need a new ac ammeter to determine the true current, right now I can only meter OHMs which might drop with actual AC applied.
Jumping over the switched to the unswitched side of the ground faiult with everything off makes small sparks so definitely some current but from I can tell it’s well under an amp.
12-09-2022, 03:33 PM
Sounds like the bathroom circuit goes to something else.
Maybe there a door bell or 24v furnace transformer hidden in the wall somewhere.
12-09-2022, 08:42 PM
en.wikipedia.org/wiki/Wheatstone_bridge
A Wheatstone bridge is an electrical circuit used to measure an unknown electrical resistance by balancing two legs of a bridge circuit, one leg of which includes the unknown component. The primary benefit of the circuit is its ability to provide extremely accurate measurements (in contrast with something like a simple voltage divider).[1] Its operation is similar to the original potentiometer.
"The Flat Earth Society has members all around the globe" -- The Flat Earth Society
12-09-2022, 11:11 PM
#9 (permalink)
There is a furnace thermostat there
