Old 09-22-2014, 11:05 AM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 59.09 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Help on running a second deep cell battery
The mod that drives me crazy but I need it for my turbo compound system
(for racing) is my Tilton 40-527 external oil pump. It doesn't help at all with FE and takes away FE from the extra load on the alternator. So I decided to add a secondary deep cell battery to run it most of the time and charge this battery at home and work. I pulled around 200lbs of weight off the car so the extra weight from the deep cell won't be to bad.
This is a post from another thread, What's your least efficient mod?
I need some help to build a system (secondary deep cell battery )that can be charge from my alternator sometimes in case of a "long distance commute", but most of the time "short commutes" it will be charged at work and home.
Electronics are my weak point so some advice would be great!!!
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-22-2014, 06:08 PM   #2 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Sounds like you need a wall charger and you alternator controlled on a switch. Other than that you just need a deep cell battery that fits under the hood or do a relocation to the trunk. Think there are a few threads on controlling alternator on a switch, I don't know how to do it but have seen posts about it.
Just double read your post and noticed you want to do a backup battery. Easiest way would be just run a deep cycle alone with no "regular" battery serving primatry duty.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
pgfpro (09-22-2014)
