Old 01-30-2010, 08:51 AM   #1 (permalink)
old red taco - '02 toyota tacoma regular cab
90 day: 29.49 mpg (US)
my next mod (what's best: rear wheel skirts + moon hub cabs or a belly pan?)
i am thinking about doing my next mod .i am thinking of doing rear wheel skirts and moon hub cabs or a belly pan. what do you guys think will give me a higher mpg gain? or is there a mod you guys know that will be more beneficial to my truck that i am overlooking.
Old 01-30-2010, 09:11 AM   #2 (permalink)
I vote bellypan.
Old 01-30-2010, 09:34 AM   #3 (permalink)
90 day: 51.82 mpg (US)
I agree with Tim: of those options, belly pan would be best.
Streamlined bed aero cap would net you the largest gain for a single mod, but you probably know that already.
EDIT: whoops, of course you knew that already ... http://ecomodder.com/forum/showthrea...p-11271-2.html
Old 01-30-2010, 11:21 AM   #4 (permalink)
i was hoping you guys would say the moon hubcaps and the rear skirts. they seem easier than crawling around under my truck. i will wait for some warmer weather to get started on the belly pan.
one other thing i was wonder is if with my aero cap would i be better with the tailgate down or up
[IMG][/IMG]
The Following User Says Thank You to ccrider For This Useful Post:
aerohead (01-30-2010)
Old 01-30-2010, 03:22 PM   #5 (permalink)
up
[IMG][/IMG]
Sepp reports from Europe,that with his testing,having the tail sealed up demonstrated the lower drag.My neighbor who ran an open tail on his Vanagon also reported lower numbers.
Old 01-30-2010, 03:24 PM   #6 (permalink)
next mod
I vote bellypan
Old 01-30-2010, 06:33 PM   #7 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
A bellypan will probably be more effective but will be a pain to fabricate, will cause servicing issues, and on a front engine/rear drive vehicle will be at best an appromation.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-30-2010, 08:01 PM   #8 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Just go with the moon caps and enjoy the minor increase until you get ready for the belly pan.
Old 01-30-2010, 09:28 PM   #9 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I vote belly pan...
You can see the progress I made with my truck in this thread...
My custom brackets really made it easier to hold up the belly pan. To take my belly pan off only requires a few bolts...but gitting to those bolts with the side skirts on takes a little more effort.
Old 01-31-2010, 02:21 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
While you're waiting for warmer weather to do the bellypan... make rear skirts and moonies
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
PT Cruiser Rear Wheel Skirts bennelson Aerodynamics 20 12-07-2011 10:22 AM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 02:12 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
