Old 04-19-2016, 04:13 PM   #11 (permalink)
no lower
Originally Posted by Istas View Post
This looks like it might be a case of "can't tell without A-B-A-B testing" since the underside is already so smooth.
I don't have numbers to back it up, but I've always been under the impression that having an airdam with the bottom edge level with the lowest point on your undertray (i.e., no lower than any point on the non-suspension parts of the car) is best, and to keep the tray level from there back to at least the rear wheels. Seems to me like having it level in front would be better than wedging more air under the car. And I think I recall hearing that it's better to have the stagnation point on the front of the car lower than higher, and the airdam would lower the stagnation point.
But I don't know. I too am not eager to duplicate work just to test.
The 1983 Ford Probe-IV concept is one example of intentionally placing the lower edge of the airdam below that of the belly.At Cd 0.152,it worked out pretty well for Ford.
BamZipPow (04-19-2016), Istas (04-19-2016)
Old 04-19-2016, 04:23 PM   #12 (permalink)
optimal
Honda probably dialed in,in the wind tunnel,what was optimum for the production car; and everything it would experience in the real world.
That would not be confused with 'ideal',which they took a completely different tack on their solar racers.
Cd 0.25 vs Cd 0.10 is a reflection of what tightening up wheel drag can mean.
Old 04-19-2016, 08:48 PM   #13 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Got my dam installed on my HCH1 today.
Factory "air dam":
Underbody aerodynamic mess:
Dam installed:
The Following 2 Users Say Thank You to Ecky For This Useful Post:
aerohead (04-21-2016), BamZipPow (04-19-2016)
