Old 01-27-2010, 04:55 PM   #11 (permalink)
pan
The bellypan on my T-100 fully encloses the driveshaft while leaving an open slot for clearance of the rear axle at full extension.
If,when jacked on stands,your independent suspension components conflict with the natural bellypan elevation,perhaps separate "pans" could be attached to each component such that at "normal" road driving,all the pieces plane out with one another.
The forward 2/3rds of a bellypan is more important than the last 1/3rd,so if you can get the front pretty clean,you're pretty much good to go.
Christ (01-27-2010)
Old 01-27-2010, 07:15 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
What a time for this post to show up! I just bought me-self an Effonefiddy.
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 06:18 PM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
