Old 05-20-2012, 09:20 AM   #11 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Belly pan makes the car hot inside in the summer.
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
skyking (05-20-2012)
Old 05-20-2012, 10:14 AM   #12 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
I'm hearing that, about the heat. I am on a search for some reasonably priced insulation blanket material to put in the tunnel section between the frames on my truck. That is where the heat will be. I have plenty of space in there for a 1~2" blanket.
I am also going to wrap my manifold, turbo, and downpipe with an insulation kit like this.
http://www.ebay.com/itm/Universal-Tu...item19caf77fb3
That should help move the heat along.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 05-20-2012, 11:06 AM   #13 (permalink)
...beats walking...
...also sorta depends upon how "firmly/rigidly" the belly pan assembly is fabricated and installed.
...if too flimsey, the panel(s) can both 'tin-can' and 'flutter' to create noise & vibrations like mad!
