Old 05-29-2013, 04:38 PM   #1 (permalink)
The Purple Prius Eater - '98 Dodge Ram 1500 Laramie
90 day: 15.07 mpg (US)
V8 Ram Saving Gas
I have a 1998 Dodge ram 1500 rwd 5.2L 318 V8 Stroked to 402cui, poly heads, ported valves, aluminum intake, larger throttle body, long tube headers with highflow cats 3 1/2" pipes with dual 3 chamber mufflers to keep is livable sound wise(I forget what kind they are), Ecu is reprogrammed to shift at lower rpms and to lock into gear from 1000 to 1200 rpm for the most part, Axle is a Dana 60 with 3.23 gears and a detroit locker for better traction on and offroad. I average about 17-18mpg the way it's all set up which is allot better than most other rams like mine get but I'm still looking for a way to get better city mileage. The trans refuses to stay in gear while going up hills even though its got more than enough power to idle up them so I think I might try another shop and see if I can have them set it up to stay locked. My other mechanic says it's not possible to completely disable that but we'll see. Oh did I mention 47k Original Miles, it's been in the family since new and only driven by my late grandfather and me this past year.
What do you guys think I could do from here to get more out of it? I'm thinking custom fabbing a Tonneau cover for the bed since I have a diamond plate toolbox and bed rails and want to keep it all intact. Other then that I think I'm at the end of the line as far as gas mileage gains.
Old 05-29-2013, 04:45 PM   #2 (permalink)
A tonneau usually improves the mileage with a comparatively low cost. Go for it at least as a starting point.
Old 05-29-2013, 04:47 PM   #3 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Tonneau is a good start
Smooth wheel covers would be a good idea
Partial wheel skirts as dodges seem to have large wheel wells
Never think your at the end as there is always something you can do
"The only real mistake is the one from which we learn nothing."
- Henry Ford
The Following User Says Thank You to Gealii For This Useful Post:
UltArc (05-29-2013)
Old 05-29-2013, 08:38 PM   #4 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Kammback, instead of a flat cover. Closed rear wheel wells. Belly pan, tire spats.
When you reach your max...you will find a new mod to try
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 05-29-2013, 10:53 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Gotta have a scangauge. See all the reasons in the first link in my signature.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-30-2013, 07:57 AM   #6 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Manual transfer swap ^
Old 05-30-2013, 01:03 PM   #7 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
Lots of stuff you can do. Everything listed so far, plus:
Grille block
Tire pressure
DWL
DWB
Manual transmission
Kill switch
Old 05-30-2013, 01:25 PM   #8 (permalink)
Park it and buy a Honda CRX.
The Following User Says Thank You to jamesqf For This Useful Post:
samwichse (05-30-2013)
Old 05-30-2013, 04:02 PM   #9 (permalink)
justme1969's Avatar
Search mega viper transmission. for about 2k never complain about the trans again and iit shifts so fast and locks up quickly so it does save mpg and power v/s splash box 518 tranny stock.
Other than this the Dodge Magnum series was never ment for economy.
It would go toe to toe with ford and chevy big blocks for most things back then but used same amount of energy.
I really LOVE my Dakota R/T but cant afford to roll it to work every day, so it sits till I need to tow something or shut up some smart butt kid.
A mega viper is a must for turbo /supercharged and Nitro 360 magnum fun.
