EcoModder.com
-   -   Best MPG without EOC and P&G ?? (https://ecomodder.com/forum/showthread.php/best-mpg-without-eoc-p-g-15291.html)
abently 11-25-2010 06:54 PM
Hi Guys n Gals,
I am curious as to what MPG's you guys are able to achieve without the usual EOC (and stop lights) & P&G ?
I am struggling to get under 5.5l/100km in a 1.3L DOHC weighing 900Kg with me in it, and am wondering if that is average, great or unbelievable ? :o
I am planning on EOC sometime in the future, once I can make it electronic, aka Prius hands off style would be nice, but till then I would like to see how low I can go and have the feeling that this MPG is potentially only average.
The engine has a few miles on it (140k), but seems mechanically A1. Though it does need a new clutch but I'm not expecting that to change my MPG figures much if anything?
I have a wideband on it and other than being in closed loop for 95% of the time, it barely goes below 14:1 with my driving style. I know that doesn't mean much given load and bsfc etc..
Anyway, feel free to post up some non EOC and P&G numbers?
I'm curious as to whether or not I should be doing better given the car I have?
skyl4rk 11-25-2010 08:19 PM
I am doing just under 40 mpg (about 6 l/km) in a 1.4 l Nissan Versa. Lately my driving style has been to coast to stops idling in neutral and occasionally coasting down hills, idling in neutral. I have done aggressive engine off coasting in the past but not in the past few tanks.
i have a grill block and a modest spoiler.
At this point, an oil heater would probably give me good results, and I want to build another boattail, which is very effective.
It sounds like you are doing a good job with 5.5 l/km. Does your vehicle have a US rating? Generally we compare our results to the US EPA rating, it allows comparing mods and driving techniques to an average rating.
abently 11-25-2010 08:51 PM
No EPA rating only an ADR rating of 6.6l/100km for City driving and 4.8L/100km for Highway, which I can put up the test procedure if someone is interested. Done on a dyno with correction factors applied after.
Can't wait to fit my MPGuino to see if I can really get 4.8L/100km on the highway.....
SentraSE-R 11-25-2010 10:43 PM
My last two vacation rentals were automatic transmission cars that I couldn't EOC in. I did P&G them, but have no idea whether it helped or hurt. I averaged close to 5.5l/100km in them (42 mpg in the Toyota Yaris with 1.5 l engine and 43.7 mpg in the Kia Rio with 1.6 l engine). Since I was doing a lot of long distance, warm engine highway driving, I'm sure my mpg would have been worse if I'd mixed in much city driving. I think you're probably doing pretty well to get 5.5l/100km without EOC or P&G. The only other thing I did for hypermiling was to keep my top speed around 90 km/hr (55 mph).
5EFE 11-26-2010 09:03 AM
I've done 57.51 with the engine running the whole time, no pulse and glide in my 1997 Tercel, about 40.1 in a 2010 Ford Fusion rental and a not very impressive 32.8 in a 2005 Dodge Stratus.
euromodder 11-26-2010 09:45 AM
It's certainly not too shabby for a petrol engine ;)
But given the weight and displacement of the car, it can get better :)
If it's worn and slipping, it will affect your mileage.
Which hypermiling tricks are you applying already ?
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
RobertSmalls 11-26-2010 09:54 AM
Why wouldn't I EOC? It saves loads of gas around town. But to answer your question, 78mpg @ 69mph on the interstate on a hot day with no A/C and the windows up. I've also done > 100mpg segments on the highway, but of course I'll EOC down the offramps, and extensively on my way to the highway.
abently 11-26-2010 05:37 PM
Feel free to explain how? Especially in a petrol car with more displacement and weight? :(
I'm running the baby 4E-FE.. :)
Even if I can achieve the highway rating of this thing, that's only 49 MPG....
abently 11-26-2010 05:44 PM
Apart from EOC and P&G there isn't much I already don't do from that list....
I think the MPGuino, once calibrated, will help me greatly so we'll see.
Weather Spotter 11-26-2010 10:16 PM
In my matrix, before my big mod add on in Aug I could get 42-43 MPG. Now I can get 44-46. If I work on it I have gotten 50 :)
