Old 11-04-2021, 08:03 PM   #1 (permalink)
Best Practices For The Geo Metro
In the last Century I was firmly in the orbit of the VW Beetle. Folk wisdom identified some helpful modifications, mostly smaller front tires and a nose down stance.
Lately I've gotten the feeling that the 21st Century belongs to the Geo Metro/Firefly. I went to the recyclers yesterday and there were two others in the parking lot. A beater just showed up in the neighborhood. A month ago I talked to someone in a parking lot that had one same year, model and color.
I've found a piece of louvered metal big enough for a grille block. I'm not above jamming a spike in each louver opening to widen them out. What percentage of air to block? 80/20? I will remove the remaining mudflaps and would like to fabricate spats for all four wheels. Any thoughts on size and placing? Bigger is better? The size of a business envelope?
ecomodder.com/forum/showthread.php/402-original-miles-2000-chevy-metro-1-0-a-39801.html#post658140
ecomodder.com/forum/showthread.php/massive-air-dam-98-geo-metro-firefly-b-9732-3.html#post555059
It looks like a flat plate, time attack style, would increase air pressure at the radiator face. Does adding a bluff faced air dam do anything more?
_________
My next goal is likely a four-wheel alignment. Not an aero question but are there preferred settings?
_________
Further along is a Kammback. I'm curious whether a minimal Fachsenfeld-edged boxed cavity would be of any help.
Old 11-05-2021, 10:23 AM   #2 (permalink)
louvers
The louvers themselves will be high-drag, suffering the vena-contracta entry losses.
I'd stay with Walter Korff's frontal stagnation point, single, bell-mouthed opening.
https://ecomodder.com/forum/member-a...speed-aero.jpg
Name:	member-aerohead-albums-other+vehicles+1-picture156-1990-itworks-crx-undergoes-serialized-high-sp.jpg
freebeard (11-05-2021)
Old 11-05-2021, 12:56 PM   #3 (permalink)
I see your point, but the purpose of the grille block is it entry losses. The openings would be pointed downward.
A secondary purpose it to be painted black with two rows of teeth for a shark moutn. I've always wanted one.
What do you think about sizing wheel spats?
aerohead (11-05-2021)
Old 11-05-2021, 01:09 PM   #4 (permalink)
losses / spats
* You can have a more 'efficient' air volume restriction without the added drag of the vena-contracta, is all I'm saying.
*As to 'spats', we need to first clarify terms.
* Historically, a 'spat' is a structure which nearly, completely encloses a front steering wheel/tire, and moves along with the 'wheel-flop.'( 1983 Ford PROBE-IV )
* What are currently referred to as 'spats', are a *******ized form of what Goro Tamai, of MIT referred to as 'taco fairings', used by solar race teams to detach-jump-and re-attach flow underneath the hour-glass openings at the front wheels.
