Old 08-03-2014, 07:24 AM   #1 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Best wheel skirt length for a 97 Civic Coupe?
Hi guys, I finally found materials to make rear wheel skirts, how far down should I go? I heard hest way is to match the lowest point on the sides, but I figured I would ask as Mud flaps are not easy to find. At least not the hard plastic lightweight ones.
Old 08-04-2014, 05:34 PM   #2 (permalink)
length
If you run a straight-edge across the wheel well,does the tire protrude at some point,or is it recessed all the way down?
If it's recessed,a full-depth skirt would be great.If not,you have options to modify the rocker panel area,pushing it out and down,such that when a skirt spans the new opening,it clears the tire.
Or just bring the skirt down as far as you can without interference.You won't be adding frontal area at least.
A photo would be helpful.
Old 08-04-2014, 05:36 PM   #3 (permalink)
Furry Furfag
I'm out at the lake right now, when I get home I'll take some pictures.
The Following User Says Thank You to Baltothewolf For This Useful Post:
aerohead (08-04-2014)
Old 08-05-2014, 04:45 AM   #4 (permalink)
Furry Furfag
Here you go aerohead, it's not the best picture but I didn't get home until after dark, if you would like more insightful pictures just let me know and I'll take some more in the daytime.
aerohead (08-05-2014)
Old 08-05-2014, 05:01 PM   #5 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
Honestly, unless you are planning on modifying the rear bumper or adding side skirts, I would go down only as far as the existing bodywork. Here is what I did, and it seems to be doing really well:
I did have to bend the lower edge so as to allow room for the tire/wheel, but it is supported with a metal piece that I hot glued to the corroplast.
The Following User Says Thank You to whatmaycome14 For This Useful Post:
Old 08-05-2014, 05:02 PM   #6 (permalink)
pictures
I GOOGLED the car and it looks like you would not be able to do full-depth skirts unless the rockers were pushed out ahead of,and behind the wheels.
Bumping things out would add a smidgeon of frontal area,but the drag reduction should overshadow that.
Front and rear skirts on the 1936 Adler Jaray was good for a 13.3% drag reduction.
If she were mine,I'd be going in that direction.(AeroCivic)
Old 08-05-2014, 06:19 PM   #7 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Full depth is how low? To the bottom of the rocker panel?
Old 08-05-2014, 06:27 PM   #8 (permalink)
bottom?
Yep!
Old 08-06-2014, 09:01 AM   #9 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
Ok thanks I should be able to do a full skirt on my KIA because the wheel sits inside. Thanks.
