Old 08-09-2009, 05:47 PM   #1 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
SAE papers?
I'm seeing referrence to SAE papers, and when I went to check, I found out that there's a steep charge for them.
What papers do people here have? I'm interested in reading papers regarding the reduction of both lift and drag.
1999-01-0651 would be a good one for people here to read:
The Influence of Aerodynamic Lift on High-Speed Stability
Abstract:
The effect of aerodynamic lift on both straight-line stability and lane-change maneuverability of several small- and medium-sized European passenger cars has been determined from subjective track tests. The straight-line and maneuvering performance degrades with increasing lift and decreasing pitching moment. Increasing speed exacerbates the problem.
Old 08-09-2009, 07:36 PM   #2 (permalink)
...beats walking...
...SAE papers are typically not free, unless the original author makes them available to the public.
Old 08-12-2009, 06:41 PM   #3 (permalink)
Sae
or you could just make the leap to Hucho's book which will have all that and then some.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
SAE Papers Available bwilson4web General Efficiency Discussion 6 04-24-2009 10:44 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
more papers (aerodynamics links) tasdrouille Aerodynamics 8 02-20-2008 07:20 PM
