Old 10-02-2008, 12:26 AM   #1 (permalink)
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
going to look at a metro tomorrow
sounds fairly rough, some issue with the 2nd gear syncro, a little body rot, but comparitievely low mileage.
what should i be looking for in terms of a compression PSI on the motor?
anything else i should look for in order to know i should run run away? im not scare of a little work, i have assembled a few cars for wheel-to-wheel racing in my life.
Old 10-02-2008, 02:04 AM   #2 (permalink)
Multiple Geo owner/3cyl
thefirebuilds
[QUOTE=thefirebuilds;64722]sounds fairly rough, some issue with the 2nd gear syncro, a little body rot, but comparitievely low mileage.
You can double clutch it into 2nd or simply time the shift. 145 lbs. per cyl. would be nice. The important thing is that the cylinders balance/read closely. Try a level spoonfull of graphite in the transmission...try some 140 weight also.
You might hear growling in the front axle(s) this is a wheel bearing. The Geo has two per wheel and they are tedious to change but a "do" with normal tools. Some people into bearings will have them for $13.00 each...Auto Zone is $30+ and Napa even higher. Get a seal also. Grease the boots heavily and might as well fill the steering boot with grease also.
What year? Some pawn shops have manuals for $5
Old 10-02-2008, 09:37 AM   #3 (permalink)
[QUOTE=owlafaye;64729]
Thanks for all the tips. Its an 89.
I had some problems with the bank today so I guess its not going to happen unless I can hawk some wares this week and make a little cash
Old 10-02-2008, 10:01 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Welcome to ecomodder. Hope you get what you want
GeoMetroforum.com - got mpg?
Diesel Metro? michigandiesel EcoModding Central 22 05-13-2013 12:42 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Saved a Geo Metro and saved big $ (stopped driving my pickup) Johnny Mullet Success Stories 24 05-08-2010 12:15 AM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 10:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 07:26 PM
