Old 10-31-2011, 11:23 AM   #11 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Very nice looking, goes along with the motto on the side of the van!
Old 10-31-2011, 02:19 PM   #12 (permalink)
90 day: 19.36 mpg (US)
Looks good, and congrats on the increase.
Have a look at orbywans work on his Class C motorhome for further inspiration.
LRR tires on that? Eliminated steering slop? Added SAFE STEER? Kenworth and Cummins are both serious about this in White Papers on the subject of mpg.
You can also look up MICROBLUE RACING for fun on lowered drag rear axle gears and wheel bearings.
Can also look at "The Aerodynamic Template" around here in conjunction with DON-BUR trailer shape (thinking roof).
Old 10-31-2011, 03:10 PM   #13 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Looks mean indeed - and slightly Mad Max
Love the spikes on the wheels, but I'd expect them to hurt the mileage a bit.
Originally Posted by Low and Mean View Post
Who would ever known trying to get better mpg would be so fun! Any suggestions on how we can improve our mpg more?
Drive 55-60 again
You're negating a good part of the improvements by using it to drive faster.
Though if time = money in your business, you could run maybe just a few tanks @ 55-60 to see the true effect of the modifications.
Flat front wheel covers.
Put a boattail on the rear using some angled, flat plates.
It's already being done to improve the mpg of semis.
If you ever need to do some work on the fairing over the cab, widen it to the width of the box.
Old 10-31-2011, 04:24 PM   #14 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Nice job - with regard to design concepts, looks, and RESULTS!
Congrats!
Old 11-01-2011, 07:05 PM   #15 (permalink)
Really nice job! The greatest potential for improvement is in the rear. A picture from behind wold be useful. If the corners of the cargo box in the back are round like in the front, then you could probably reduce drag by making them sharp and sticking out a bit, on the end of the side and top panels, to promote flow detachment.
Old 11-03-2011, 01:17 PM   #16 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
We bought a turbo added a innercooler and propane injection, which really improves the performance and mpg. Then we covered the rear wheels and wrapped the van with a 12" rubber skirt. The last step is the big front bumper we made out of fiberglass with a rubber skirt below. The end result we took a van from 10-11 mpg to 14-15mpg going 60-65 mph (where before we could only get 55-60mph max speed).
Are you including the propane burned when you calculate mileage? What is the percentage of propane in your fuel mix?
Old 11-03-2011, 05:49 PM   #17 (permalink)
It appears that the addition of Aero and PI have made the vehicle capable of a higher overall road speed (which, with weight, means better choices about hill climbs) and lending greater main fuel range. Which should be impossible, right?
Old 11-08-2011, 05:38 PM   #18 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
LM
A pillar must have an air deflector with vortex generators to improve flow avoiding flat surface drag.
The upper Air drag need more width to ensure flat surface drag is reduced (and reducing flat surfae for a curved air friendly one).
A Boat Tail will help a lot on lowering drag.
Nokian or Continental VancoContact2 tires with c.r.r = 0.0064 if is possible, Michelin Agilis crrr = 0.0071, with the same rubber, and width coefficents of rolling resistance is lower if radius is higher. Linear dependence is showed in european tests for ecolabelling tires.
Congratulations of your mods.
Sold:
Old 11-08-2011, 08:37 PM   #19 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
KEEP THE FRONT TIRES!!!!!!!!
any SLIGHT lose in mpg is made up in a HUGE amount of ATTITUDE!!!!
somebody snears at you and you can "BEN HUR" them!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Cd (11-11-2011)
Old 11-10-2011, 01:18 PM   #20 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Remove the rear dually wheels put a spacer (that they sell for this) on then one commercial tire a side. Fuel savings may be as high as 2 or 3 mpg.
Remove mirrors add wide angle cameras mounted on a piece of pipe that is bolted to the original mirror mount points.
My guesstimate is the mirrors would save 1 -2 mpg, making possible 4 -5 mpg combined improvement on top of what you have done already,possible you could get 19-20 mpg in your cube van.
*Wow* that would be a cube van miracle that your close to making a reality.
I bet you could sell your Eco mods to other van operators.Great work you have done.
Save gas
