Old 08-23-2008, 03:54 PM   #1 (permalink)
2000 Civic EX - '00 Honda Civic EX
90 day: 36.97 mpg (US)
Send a message via AIM to ESmooth
Big improvement on very 1st tank!
I went from a max of about 30MPG (before coming here) to 36.46MPG using some EOC, drafting and just driving slower overall and that was without a scangauge. My SGII just got delivered today so my goal of 40MPG should be pretty easy. I just did some maintenance stuff as well including replacing a clogged PCV valve which is known to be a mileage killer as well as replacing plug wires, cap and rotor, fuel filter and upping my tires to 50PSI from the 42 I had them at before. I also picked up some garden edging black plastic stuff I want to try to fashion into some sort of grill block and air dam. Thanks EcoModder!
Old 08-23-2008, 04:08 PM   #2 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
First tank at 30% over EPA is great result
I began lower and improved without SG2 (not compatible ), so you can expect bigger and faster improvements than mine
Congrats,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 08-28-2008, 09:51 PM   #3 (permalink)
Did an early fillup since I found a great price for gas and came out with 39.1MPG. I was hoping for 40, but Im pretty sure that I would have reached it if I went a little longer. High hopes for 40+ on my next tank now that my SGII is calibrated. I also found myself driving more than normal to get used to the SGII and some of the techniques so all things combined, 40 should be a walk in the park! I should also add that I replaced a bad PCV valve, new plug wires, new cap and rotor and 50PSI in the tires. Also a quick and dirty WAI by removing the air intake tube that comes out of the bottom of the airbox.
Old 08-29-2008, 10:23 AM   #4 (permalink)
Very nice gains. Pretty soon 40 will be 'bad' mileage for you!
Old 08-29-2008, 03:34 PM   #5 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Chevy Metro LSi
90 day: 48.88 mpg (US)
ESmooth - can't wait to see your garden grow
Combined EPA Rating ... cheaters up in here or just a big misunderstanding?? Markmysite Hypermiling / EcoDriver's Ed 30 10-15-2009 02:00 PM
Smaller Fuel Tank steensn EcoModding Central 5 07-11-2008 01:09 PM
The acetone test trikkonceptz EcoModding Central 88 06-16-2008 10:27 PM
First tank w SG homeworkhome53 Instrumentation 3 04-13-2008 11:57 PM
Fuel tank size on 2000 Sunfire? bennelson EcoModding Central 10 02-10-2008 09:34 PM
