Old 11-28-2008, 11:29 AM   #1 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Yet more complaining about winter
I just had my worst tank since last June.
I mostly did in-town driving, in the snow. I don't even turn on the car while I scrape snow and ice!
However, snow leads to way too much wheelspin, which is racking up miles and burning fuel. I think that's my biggest problem, and living in one of the snowier regions of New York really isn't helping. To add insult to injury, the secondary roads I EOC on during my commute are extremely low-traffic, so tend to remain iced over (leading me to avoid them).
I'm not looking for advice, just venting. Winter gas, cold weather, and snow have cost me 5mpg (overall)! My 90-day average is going to drop off a cliff soon, as my really good tanks from late august/early september stop being figured in.
Oh well, at least I know I can still beat the combined EPA fuel consumption numbers by several mpg in sub-optimal conditions.
Old 11-28-2008, 09:49 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I know exactly what you mean. The roads here in the Great Lakes region are mostly snow covered and rough. My block heater made a major improvement, but I cannot touch my summertime MPG numbers anymore.
GeoMetroforum.com - got mpg?
Old 11-28-2008, 10:49 PM   #3 (permalink)
bluesfan's Avatar
The Bluesmobile - '08 Mazda B2300 2WD
90 day: 22.62 mpg (US)
Yep, winter sucks. I have a block heater, but no timer yet, so I usually plug it in before I hit the sack. Likely using more electricity than I should, but at least the scangauge says the coolant temp is around 100° F when I start the bluesmobile in the morning.
LRR specs are hard to find as we all know. On my mechanic's recommendation, I picked up a set of Toyo Open Country G-02 Plus winter tires. I found aluminum rims at a local wrecking yard -- made for a mid-90s Crown Vic / Grand Marquis, but perfect fit for my truck.
I installed an upper grill block as well -- plexiglass attached with four zip ties. Hopefully there will be aero and thermal benefits.
The nut behind the wheel still need fine tuning...
In reverent quest of the last mpg...
Old 11-28-2008, 11:58 PM   #4 (permalink)
Boxhead
It would probably behoove me to get a block heater. I could probably even get away with plugging it in at work, too.
My grille's about 85% blocked at this point, and I think that does help a little.
Oh well-- it just snowed a whole bunch more today.
/continues grumbling away from the intertubes
Old 11-30-2008, 07:52 PM   #5 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Just drove across Missouri in light rain/snow around freezing...saw I hit. I think I still squeezed 40mpg, but it's questionable.
Old 11-30-2008, 08:15 PM   #6 (permalink)
Hi-Tech Redneck
My boss seen my car plugged in out back and asked if I converted my Metro to all electric
I explained the block heater and he does not mind me plugging in at work. I am now going to make a short extension cord I can carry in the car and another cheap timer.
Old 11-30-2008, 10:21 PM   #7 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
Hrm... I know what you mean... I got brand new tires (with full tread), have been driving with more attention to the road than FE, and have done a ton of start-stop in the driveway when dad decides to plow the snow away. :-\
Old 12-22-2008, 04:21 PM   #8 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
Was your Dad using your car to plow snow?
We went up north to do some icefishing this weekend and did alot of driving in 4wd and 4th gear on icy roads and then 30 km in 3rd gear with snow up to the axles... Still ended up with about 10L/100km for the tank which isn't too bad.
Ian
Old 12-23-2008, 12:37 PM   #9 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I spin a lot going to work and back but surprisingly it doesnt amount to hardly anything on my overall distance, which is about 25.6 miles one way.
Ive gotta move mine a few times when plowing the driveway too.
Winter daily driver, parked most days right now
Summer daily driver
[MetroMPG.com] List of reasons why your winter mileage is so bad MetroMPG General Efficiency Discussion 34 01-02-2013 06:03 PM
Summer vs Winter tires SmartTrucker EcoModding Central 11 09-03-2008 01:15 PM
Quick fuel saving tip for Winter Johnny Mullet EcoModding Central 26 08-24-2008 02:27 AM
Winter weather mod problems.... justpassntime Aerodynamics 7 08-05-2008 11:35 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
