bla bla bla
This forum steals ideas and claims them as their own!
http://ecomodder.com/forum/414618-post41.html Don't join! |
I love projects like this! Keep 'em coming.
I'm curious how the new antenna does. Keep us posted.
1 Attachment(s)
Maybe like this?
http://ecomodder.com/forum/attachmen...2&d=1393443468 Now it makes more sense to me. ;) |
1char
1char
Do you notice a difference in acceleration or better handling with the reduced weight? 50KG is quite a lot, but I honestly don't notice much of a difference between just me driving, and driving with my wife in the passenger seat.
I just made an upper grill block out of white coroplast, and it looks good and is holding up well. http://i7.photobucket.com/albums/y26...m/KIMG0019.jpg I've left the top gap alone since it wasn't as easy to wedge the coroplast in there, and there needs to be easy access to the engine. Half of the lower grill has been crudely blocked with pipe insulation. I might block the lower section off as well, since temps haven't been going above 185F. |
Be careful when blocking both. My Accord worked very well for several months, but then started overheating. Learned that the blocking caused the old fans to run much more than they were used to and the fans failed. Had the expense of replacing fans...:(
1char
