Old 12-16-2011, 09:07 PM   #11 (permalink)
90 day: 19.36 mpg (US)
Some of the folks over at Cummins Forum are noting warm up time quite a bit quicker and to higher temps (using a scan tool to read the stock sensor).
Must be on the 6.7L threads . . got a link? AH64ID at CF is, on the subject of the stock block heater, fond of saying: "90% of the benefit in 90-minutes".
As to aftermarket: The posts & threads I've bookmarked or recalled specifically recommended HOTSTART Thermosiphon : railroad, oil field, power generation, etc. Big equipment and little fleet trucks (like ours).
Old 12-16-2011, 10:11 PM   #12 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
What your block heater can do in 2 hours my car can do in under minute by itself. Is it really worth the extra electricity usage?
In Reason we Trust
Old 12-17-2011, 12:06 AM   #13 (permalink)
For probably 10 cents/hr it is worth it, if not plugged in to excess.
Old 12-17-2011, 07:46 AM   #14 (permalink)
Wagon - '06 Ford Focus zxw
90 day: 29.69 mpg (US)
I plug my stock block heater everyday, there's around 40 degrees difference between the outside temps and the engine temps after 10 sec running. The heater is on a 2hr timer
I get heat much faster and operating temps comes up 1-2 minutes faster.
I would really like to get a tank type heater but I can't find any that fit my car
Old 12-17-2011, 08:29 AM   #15 (permalink)
tru
tru - '05 Ford Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 GMC Sierra Denali
so for 30-40 cents each day, how much gas do you think you save in that 1-2 minutes?
-im being serious (not trolling)
Old 12-17-2011, 03:40 PM   #16 (permalink)
I don't know, but it does save gas, and it also saves on engine wear and tear. And if you want heat and defrost right away that works better too.
P.S. 1 1/2 hrs per day isn't 40 cents, it's <15 cents.
Old 12-17-2011, 05:59 PM   #17 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Agreed. I think just from a cost of electricity vs cost of fuel it's probably about even, but I figure the wear and tear benefit turns it into an overall benefit.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 12-18-2011, 05:41 AM   #18 (permalink)
It also depend from your fuel/electricity cost.
I'm paying around 5$ a gallon but electricity is 7c/kw so it's probably well worth it for me
