Old 05-13-2009, 08:20 PM   #1 (permalink)
Shadow - '93 Dodge Shadow ES
90 day: 24.34 mpg (US)
Moped - '06 Metro 50
90 day: 137.2 mpg (US)
Block heater in summer?
I'm fortunate enough to have an engine block heater on my Shadow. I used it some in winter, but is it still worth using in summer? Will it heat the block enough to boost efficiency?
Old 05-13-2009, 09:10 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
The sooner that engine is out of "closed loop" mode, the better the mileage. I plug mine in for 30 minutes before starting in the warm months and longer in the winter.
GeoMetroforum.com - got mpg?
Old 05-13-2009, 09:57 PM   #3 (permalink)
90 day: 51.82 mpg (US)
Definitely an efficiency advantage in the warmer months too. I plug mine in when I'm not feeling lazy.
I forgot to bring an extension cord to the Green Grand Prix mpg rally, or I would have used it there as well.
Old 05-14-2009, 07:23 AM   #4 (permalink)
Yup, I use mine too. Like the others have mentioned, I shorten the time it runs in summer, and lengthen it in winter.
Old 05-14-2009, 11:46 PM   #5 (permalink)
Tried it out today. Noticed it warmed up a good deal faster than without. I think ill start using it with my battery charger to top up before a trip (EOC without bumpstarting drained my battery enough to keep it from starting today.)
Old 05-15-2009, 10:59 AM   #6 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I've found that my block heater will bring the coolant temp up to about 80°F. So if I remember to plug it in, I use it during the warmer months, until we start getting over 80°F during the day.
Old 05-15-2009, 11:23 AM   #7 (permalink)
A block heater should be able to provide a set temperature above ambient (delta T). If you can get 80 degrees when it is 30 out, you should be able to get up to 130 degrees when it is 80 out.
Old 05-15-2009, 11:23 AM   #8 (permalink)
But doesn't your block heater raise the engine temp more or less by a set amount, relative to ambient?
Meaning: if it'll raise it from 30F ambient to 80F, won't it raise it from 80F ambient to 130F?
Old 05-15-2009, 11:24 AM   #9 (permalink)
Haha - jinx!
Old 05-15-2009, 11:25 AM   #10 (permalink)
If your battery is getting low enough to prevent a start, won't be long before you'll be needing a new one!
Also for best longevity, you should charge as soon as possible after discharging it, rather than letting it sit discharged and then charging right before the next use.
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
Grill and valence block, summer port opening size? skyl4rk EcoModding Central 10 03-25-2009 06:17 PM
An Engine Block Heater in San Jose Who EcoModding Central 20 07-28-2008 05:44 PM
