Old 01-05-2016, 06:28 PM   #1 (permalink)
PSmodder lurker
NASA's aero technology to save aviation industry billions
NASA's Environmentally Responsible Aviation (ERA) project is pioneering new green technologies for the aviation industry. Technologies to reduce fuel consumption, aircraft noise and low-carbon aircraft.
Technologies include; new composite material fabrication, engine efficiency improvements, special outer coatings to reduce weight and air drag from insect strikes/splatter, weight reduction by recommending shorter tail fins with embedded air nozzles for better control, morphing wing shapes with multiple sealing flaps to close all flap/body gaps (reduces noise and efficient surfaces) and new hybrid wing body shapes.
NASA Wraps Up First Green Aviation Tests | NASA
NASA Successfully Tests Shape-Changing Wing for Next Gen Aviation | NASA
Glow with the Flow | NASA
Aeronautics | NASA
The Following 5 Users Say Thank You to botsapper For This Useful Post:
aerohead (01-06-2016), BamZipPow (01-05-2016), niky (01-06-2016), rumdog (01-08-2016), Xist (01-11-2016)
Old 01-07-2016, 12:16 PM   #2 (permalink)
PSmodder lurker
NASA's Hybrid Electric Aircraft Concept
Subsonic Ultra Green Aircraft Research (SUGAR) along with Boeing, created a concept to use distributed turboelectric powered engines for typical short-range flights. Efficient regular jet engines are used for more power in take-offs, then electric power supplement and even takeover the turbofans in lower/zero emission level/cruising flights. Plane concept designs to quieter, reduce fuel burn emission by 70% and be viable in 2030-2050 time frame.
http://www.nasa.gov/feature/research...arbon-aircraft
The Following 3 Users Say Thank You to botsapper For This Useful Post:
aerohead (01-09-2016), BamZipPow (01-07-2016), Xist (01-11-2016)
