Old 08-21-2009, 12:14 PM   #1 (permalink)
Pickup Fuel Meiser
Blackline - '09 Nissan Frontier King Cab SE V6
Jetta - '11 Volkswagen Jetta Sportswagen TDI
cooler air via the vent?
What drove me nuts about my old car was that the air coming out of the vent was much warmer than outside air, meaning it can be pretty miserable driving on the highway with the vent on instead of the A/C.
Now it turns out my new truck is even worse. It seems like the air from the vent 10-15 degree than the outside air. Are there any modifications I could make to allow cooler air into the cab via the vent? Where exactly is this heat coming from? Come to think of it, where exactly does the air from the vent come from?
Frank
RIDE A BIKE!: "If by tomorrow, every gas guzzler on the road were replaced by Priuses, we would still have the same gridlock, accidents, deaths, injuries and the same pressures to put more asphalt, strip malls and subdivisions." --Thomas Smart: SuperCommuter
Old 08-21-2009, 12:22 PM   #2 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
warm air from vents
the reason why your air is so warm is probably because it has to go down past the firewall, WHICH IS WARM. the fan in my car is right behind the exhaust header on the ENGINE side of the firewall!! But i don't have to turn the fan on to get warm air in winter. i just turn the heat control up and let the warm air circulate through the car naturally. If you want to get cooler air maybe you could fab a heat shield for your firewall/fan area to cool things down, or maybe put your fan under/ behind the glove box like some other trucks. Maybe you could post pics of fan area. the intake for the fan is usually by the wipers so it would probably help to install heat shield.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 08-21-2009, 03:45 PM   #3 (permalink)
Pickup Fuel Meiser
So, I looked under my hood, and those air intake areas right in the back below the windshield are where the vent goes in? And the metal plate at the back of the engine compartment is the fire wall? If that is the case, I think I could easily put some fiberglass insulation between the engine and that firewall right around where the vent is, but won't the firewall get warm from conducted heat as well?
Frank
Old 08-21-2009, 04:33 PM   #4 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Trucks used to have vents at the floor which would pull outside air from under the truck. Maybe you could rig something similar.
Old 08-21-2009, 07:40 PM   #5 (permalink)
Then you increase the amount of exhaust you suck in
Old 08-21-2009, 07:56 PM   #6 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
I believe those pulled from the front fenderwell. I never noticed an exhaust smell.
Old 08-21-2009, 10:28 PM   #7 (permalink)
From other cars I mean. Seems like you'd be pretty close to where everyones' tailpipes are
Old 08-22-2009, 04:08 PM   #8 (permalink)
heat
If after running the engine and then turning it off,hat may stratify under the hood,exposing that region which contains the fresh air ductwork to this heat"flux" and raising temps of fresh air once you drive off again.------- After a period,the cooler incoming air should carry off this heat( unfortunately onto you).then settle out at a discharge temp closer to outside ambient temp.--- If you can take the heat for awhile it will go away.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
