Old 08-15-2013, 02:55 PM   #1 (permalink)
Fastener/mount suggestions:
i want to start with installing a bellypan(do the most difficult thing first). Actually this won't be a full-fledged bellypan; It will cover the area between the framerail outboard to the body.
Do you have any fastener/mount suggestions or pictures?
Note that this is a chevy pickup so it's got full framerails from bumper-to-bumper. i'm thinking, right now, that heavy duty zipties might be sufficient. i will probably use masonite for the panels, since that is what i have lying around the house.
83 1/2 ton chevy pickup
15.82 avg. mpg
17.56 Best mpg
Old 08-15-2013, 04:31 PM   #2 (permalink)
darcane's Avatar
I made a frame using steel strips with pre-drilled holes (from Home Depot?). Since I couldn't get to the back of the frame when I put the belly pan on, I used speed nuts (aka spring nuts or U nuts, similar to these: 3/8"-16 Panel Range:.050"-.200" Center 3/4" Extruded U Nut | Fastenal) and small screws with washers, with Loctite blue.
Frame:
Belly pan:
Belly pan was on there for four years and never once had to do anything with it.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following 2 Users Say Thank You to darcane For This Useful Post:
Capt. Pinbacker (08-16-2013), Cd (08-17-2013)
Old 08-15-2013, 05:38 PM   #3 (permalink)
grins2go_brett's Avatar
It depends on how heavy the Masonite is. If you used coroplast, you wouldn't need much more than screws. For the body side, you most likely have a pinch-weld that sticks down about an inch from the rest of the sheet metal. Drill and screw directly into the sheet metal on the frame side of the pinch weld. Use short screws no more than an inch long. That's an open area behind that sheet metal where you won't hurt anything. For the frame, one member here (AeroRV) attached a piece of wood to the bottom of his frame rails so he minimized the holes he had to drill into the frame, and could drill as many holes has he wanted into the wood, easily. Also, zip ties can work very well if the holes you have for attachment line up well.
The Following User Says Thank You to grins2go_brett For This Useful Post:
Old 08-15-2013, 08:21 PM   #4 (permalink)
Century - '03 Buick Century
90 day: 35.41 mpg (US)
I made mine out of 1/4" luan screwed into some wood pieces and metal as needed to jump across the large spans.
I've used masonite for concrete forms to make curves and it holds up OK, but you might not get a bunch of life out of it unless you spread the load out with more screws in a larger area for when it gets wet. The truck frame has enough holes in the lower flange to attach plenty of wood supports. The outside endge is the hard part. I drilled through the pich weld on the car to attach some more wood and then attached the Luan. I can't picture the bottom of the truck cab or bed right now to know if that will work. I always thought that I could do a no drill install of some flanges by screwing two strips of material together on top of each other, but with the car body in between one edge of the strips, leaving the screw to clamp the strips and give you a flange to attach the belly pan.
My profile has pictures of my Century's belly pan in it. It has been installed for quite a while with no issues and has certainly been wet many times.
The Following User Says Thank You to olds455 For This Useful Post:
Old 08-16-2013, 10:04 AM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Sorry, but you put it in bold.....
did you EVEN try to do a search of the ecomodder search button?????
I bet there are 50-60 threads WITH PICTURES....DETAILED PICTURES.....
I mean, you've been here since 2011......have you read ANY threads in 2 years......
but here is a hint...save you having to do any work......
see the third link in my signature.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Old 08-16-2013, 01:01 PM   #6 (permalink)
Insert wood dowel rods or cheap aluminum tent poles of proper thickness into the flutes of the Coroplast wherever you need extra strength or stiffness. Ziptie around the dowel rods to suitable hard points on the vehicle, such as stabilizer bar cross piece, etc.
The Following 2 Users Say Thank You to Otto For This Useful Post:
aerohead (08-16-2013), Capt. Pinbacker (08-18-2013)
Old 08-16-2013, 10:28 PM   #7 (permalink)
Coroplast. Welding rod in the flutes with the ends bent into loops. Self-tapping sheet meatl screws. Ta Da!
