Old 06-24-2020, 01:45 PM   #1 (permalink)
Box Truck aerodynamics paper
I GOOGLED 'lowest drag box truck in USA'
which took me to :
Aerodynamic Drag Reduction Technology Testing of... NREL,
@ nrel.gov/docs/fy17osti/64610.pdf
Engeu1 (06-24-2020)
Old 06-25-2020, 05:07 PM   #2 (permalink)
which took me to :
via DDG:
Aerodynamic Drag Reduction Technologies Testing of ... - NREL
https://www.nrel.gov/docs/fy17osti/64610.pdf
National Renewable Energy Laboratory Produced under direction of California Air Resources Board (CARB) by the National Renewable Energy Laboratory (NREL) under Work for Others Agreement number FIA-11-1763 and Task No WW4A.1007. Technical Report NREL/TP-5400-64610 . October 2016
You can copy-and-paste the cite and vBulletin will linkify it for you. Twice but I delete one.
aerohead (06-26-2020)
Old 06-30-2020, 07:17 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Interesting article. Thanks for posting the link. My big takeaways: Testing is hard even for professionals. There are things that can be done to reduce aerodynamic drag in box trucks. It really depends on the intended use of the truck whether it is worth doing or not. For city trucks the extra weight may hurt efficiency.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following 2 Users Say Thank You to COcyclist For This Useful Post:
aerohead (07-06-2020), MeteorGray (07-01-2020)
