Old 11-13-2012, 07:54 PM   #11 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
use your oem block heater a lot
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 12-03-2012, 10:42 PM   #12 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Started today the commute to school. Was going slow ~40-50 MPH on the hwy. Did DWL, DWB, Engine On Neutral Coast, timing trafic lights and no aeromods .I don't know how much gas I have taken, because I don't have a SG, but I hope to see 7 LHK (33 MPG). EPA is 23 City 31 HWY 26 CMB.
I've inflatwed the tires in the returning leg. The recommended is 36 PSI, and the max is 44, so I put 40 PSI. Were going to see if it makes a difference...
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 12-03-2012, 11:21 PM   #13 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Get instrumentation. ultra/scan gauge, or a guino. You will then know if you are getting DFCO and you will know if in our out of gear is better for your car.
Seriously, we were getting 38mpg as an occasional woo that was an awesome tank, using the mojo that I learned in the civic (with instrumentation). Put an UG in the escort and 42 is pretty normal (it will be dropping with winter comming on but 38 has been the "low" tanks where 35ish were decent winter tanks) no matter how good you think you are a scan/ultra gauge will pay for it self if you interpret and adapt correctly to it. (UG is cheaper so the payoff is a bit quicker)
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following User Says Thank You to bestclimb For This Useful Post:
HyperMileQC (12-07-2012)
Old 12-04-2012, 02:29 PM   #14 (permalink)
Gen-1 Insights
Gen-1 Insights
Pugged the Block Heater this morning, it didn't seem to work.. When I sat in the car and started it, the temp was as low as yesterday (No block heater plugged). plugged it for almost 1H30 min. SO don't know if its need more time or if it doesn't work. It is a 400w OEM Block Heater that you put in the frostplug.
I plan to buy a SG, but I have to ship it were I live. so $$...
Also planning to put Smooth wheel covers and grille block.
Old 12-04-2012, 02:40 PM   #15 (permalink)
Busting Knuckles Often
Blue Maxx - '04 Chevrolet Malibu Maxx LT
Team Chevy
90 day: 26.96 mpg (US)
Tink's Van - '08 Chrysler Town & Country Touring
90 day: 19.09 mpg (US)
2004 5 Speed Goldrolla - '04 Toyota Corolla CE
90 day: 36.3 mpg (US)
Quick check
OK, plug in a lamp or something on the same circuit as your heater. turn on the lamp. Does it dim when you plug in the heater, and get bright again when heater is unplugged? I know, not fancy, but works for me
Also, after you run it for a while, open hood, the engine should feel warmer to the touch than anything else in the engine bay.
Was your coolant gauge was not even popping a little bit off of the Cold mark?
You should see something with 400 Watts for 1.5 hours... Same size EBH as mine, on a bigger engine than yours. Hmmm
Also, make sure EBH is UNPLUGGED prior to starting engine.
The Following User Says Thank You to WesternStarSCR For This Useful Post:
Old 12-04-2012, 03:05 PM   #16 (permalink)
I run my Prius' block heater for about 1.5 hrs and it gets up to roughly 70F / 21C. That isn't enough to register on a normal temp gauge right away. On my Paseo you have to see 100F / 38C at least before the needle starts to move. You need a scangauge or other device to get any accurate readings.
The Following User Says Thank You to Daox For This Useful Post:
Old 12-05-2012, 08:26 AM   #17 (permalink)
Gen-1 Insights
Gen-1 Insights
Coolant temp wasn't showing any improvement in temperature.
I could not feel heat from the engine when opening the hood and unplugging the EBH.
Anyway, plugged it today, well see if it works...
The Following User Says Thank You to HyperMileQC For This Useful Post:
WesternStarSCR (12-07-2012)
Old 12-05-2012, 09:01 AM   #18 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Kill-a-watt. That is all.
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
HyperMileQC (01-10-2013), WesternStarSCR (12-07-2012)
Old 12-07-2012, 11:27 AM   #19 (permalink)
Gen-1 Insights
Gen-1 Insights
Update :
Will change oil this week-end (SAE 5W-20). Doing wheel covers and grille block.
hit 300 km (186 miles) on the way to school and I'm at the end of the second quarter (gas monitor). Estimation for now... ~7.7 LHK (30.5 MPG).
Old 12-12-2012, 02:00 PM   #20 (permalink)
Gen-1 Insights
Gen-1 Insights
Update :
hit 535 km (332 miles) today, gas gauge shows 1 quarter of tank. Estimation for now : ~7.0 LHK (33.6 MPG). Good news soon! I hope...
automatic, block heater, commute, mazda 3, winter
