Old 02-22-2013, 05:44 PM   #61 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Update : warmer morning (-4°C) without snow and little wind. c°WT showed 36°C before starting. EBH plugged for 3 hours 30 minutes. SG said 5.5 LHK so I got around ~6.3 LHK in reality.
On the returning trip I got lot of traffic in the two town parts of my commute. c°WT showed 5°C. SG said 5.5 LHK so I got around ~6.3 LHK in reality. Didn't used lights, had to use heat in the traffic. Hit 409.3 km today and FL% showed 46%, gas gauge shows 2/4.
AVG of the day : 6.3 LHK (37.3 MPG US).
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 02-25-2013, 04:10 PM   #62 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : Nice warm morning (1°C) without snow and little wind. c°WT showed 41°C before starting! EBH plugged for 3 hours 30 minutes. SG said 5.2 LHK so I got around 6 LHK in reality. Did under 10 LHK for the first part of trip (town).
On the returning trip, temp was 0°C and c°WT showed 17°C. SG said 4.7 LHK after highway and increased to 5.2 LHK than dropped to 5 LHK so I got around 5.8 LHK in reality, wich is great! Hit 477.8 km today and FL% showed 40%, gas gauge shows just a little bit higher than the middle of 2/4.
AVG of the day : 5.9 LHK (39.9 MPG US).
Old 02-26-2013, 06:05 PM   #63 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : Warm morning (2°C) without snow and little wind. c°WT showed 37°C before starting. EBH plugged for 3 hours 20 minutes. SG said 5.2 LHK so I got around ~6 LHK in reality. Again did under 10 LHK for the first part of trip (town).
On the returning trip, temp was 1°C and c°WT showed 19°C. SG said 5.2 LHK so I got around ~6 LHK in reality.
I also dit a ~30 kilometer trip on which SG averaged 5.35 LHK, so I got around ~6.15 LHK in reality. Hit 586.2 km today and FL% showed 27%, gas gauge is near the 1/4 mark.
AVG of the day : 6.1 LHK (38.5 MPG US).
Old 02-27-2013, 05:11 PM   #64 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : Warm morning again (2°C) without snow but windy. c°WT showed 40°C before starting. EBH plugged for 3 hours 30 minutes. SG said 5.4 LHK so I got around ~6.2 LHK in reality.
On the returning trip, temp was 3°C and c°WT showed ?? forgot to check. SG said 5.3 LHK so I got around ~6.1 LHK in reality. Hit 654.2 km today and FL% showed 20%, gas gauge is a little bit under the 1/4 mark.
AVG of the day : 6.15 LHK (38.2 MPG US).
Old 02-28-2013, 05:44 PM   #65 (permalink)
Here in sweden the salt alot so you need to wash with water all the time!
Old 03-01-2013, 10:26 PM   #66 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : Warm morning again (1°C) with snow and some wind. c°WT showed ?? forgot to check. EBH plugged for 3 hours 30 minutes. SG said 5.5 LHK so I got around ~6.3 LHK in reality.
On the returning trip, temp was 1°C and c°WT showed ?? forgot to check. SG said 5.3 LHK so I got around ~6.1 LHK in reality. Hit 723.7 km today and FL% showed 12%. Gas light is on, will refuel monday. Gas gauge is near the end of 1/4.
AVG of the day : 6.2 LHK (37.9 MPG US).
Old 03-04-2013, 12:27 PM   #67 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : colder morning (-7°C) with lot of wind. c°WT showed 37°C before starting. EBH plugged for 3 hours 35 minutes. SG said 5.8 LHK so I got around ~6.6 LHK in reality.
On the returning trip, temp was around 0°C and c°WT showed 45°C before starting. SG said 5.2 LHK so I got around 6 LHK in reality. Hit 792.0 km today and FL% showed ??. I went to the gas station today and filled up & calibrated my SG. I did 788.9 km on 51.168 liters of fuel, that gives 6.49 LHK (36.27 MPG (US)).
Almost did 500 miles on this tank, could have done it thought...
Old 03-05-2013, 03:37 PM   #68 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : first commute with the SG calibrated. cold morning (-5°C) with snow and wind. c°WT showed 39°C before starting. EBH plugged for 3 hours 25 minutes. I took another route this time cause I had to do a lift to my brother. SG said 7.1 LHK.
On the returning trip, temp was around 0°C and c°WT showed 17°C before starting. SG said 5.9 LHK. Hit 67.1 km today and FL% showed 92%.
AVG of the day : 6.5 LHK (36.2 MPG US).
Old 03-06-2013, 07:54 PM   #69 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : Warmer morning (0°C) without snow but a lot of wind. c°WT showed 35°C before starting. EBH plugged for 3 hours 35 minutes. SG said 6.4 LHK.
On the returning trip, temp was around -1°C and c°WT showed 3°C before starting... I had to use my lights. SG said 6.0 LHK. Hit 135.9 km today FL% shows 82%. Seemed to have dropped quickly...
Old 03-07-2013, 06:13 PM   #70 (permalink)
Gen-1 Insights
Gen-1 Insights
Update : Warmer morning (-1°C) without snow and little wind. c°WT showed 38°C before starting. EBH plugged for 3 hours 35 minutes. SG said 6.6 LHK.
On the returning trip, temp was around -2°C and c°WT showed 2°C before starting... There was some traffic. SG said 5.9 LHK. Hit 204.3 km today and FL% shows 74%.
automatic, block heater, commute, mazda 3, winter
