Old 10-11-2012, 10:35 PM   #11 (permalink)
Originally Posted by Piwoslaw View Post
That is true only if you replace a naturally aspirated engine with a downsized turbo'd engine. It's hard for me to imagine when just slapping on a turbo would lower fuel consumption, especially if you aren't immune to the urge of flooring it every now and then
If a specific engine is quite underpowered for a given model, such as the 2.0L 4G63 used in some versions of the Mitsubishi L200 pickup and L300 van, a turbo can make miracles due to the torque increasement thru a broader RPM band.
We might not forget the effects of turbocharging into Diesel engines and how it increased their overall efficiency...
