Old 09-20-2010, 10:05 PM   #161 (permalink)
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
5E-FHE Engine, in Japanese, and grams/Ps.H so you'll need to convert Ps to Kw or HP, but that's not hard.
Working on getting the 4E-FE one... I'll see if I can get the 5E-FE as well.
Old 09-21-2010, 10:28 AM   #162 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
It shows BSFC versus RPM, but how hard to you have to press the throttle to get those numbers? We'd really like to know BSFC vs RPM and torque.
Old 09-21-2010, 10:39 AM   #163 (permalink)
True, a load based BSFC is much more ideal. However, this is better than nothing.
If you could get a 2nd generation 5E-FE that would be great!
Old 09-21-2010, 11:29 AM   #164 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Originally Posted by tasdrouille View Post
Might be a dumb question, but what is a Graham scanner?
It scans graham crackers so you know the best way to dunk them in milk to get the best possible absorption without making the cracker soggy.....
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-21-2010, 09:09 PM   #165 (permalink)
I get the impression they potentially got that output running it in 4th gear from 1000-7000rpm, and I am assuming they got that result on the road, not off some engine or vehicle dyno test.
Would make logical sense, to have vehicle weight and aero drag factored in to that chart, but then again, if you wanted to show min fuel consumption, you wouldn't want it tested that way....
Old 09-21-2010, 09:13 PM   #166 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I can assure you that the numbers are created with the use of an engine dyno, Load depends on the manufacturer.
Being that these charts are very rarely published I doubt they go through much trouble "marketing" the numbers.
2012 Tesla Model S P85
2013 Nissan LEAF SV totaled by now deceased intoxacated driver.
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 09-22-2010, 08:43 PM   #167 (permalink)
I suspect thats the case on both accounts.
Old 09-26-2010, 06:58 AM   #168 (permalink)
A quick question regarding live BSFC data.
Is it possible relatively speaking, to judge whether BSFC is better or worse, by comparing RPM and duty cycle change?
I.e, say at 60km/hr, rpm is 1800, and duty cycle is 14% in 5th gear, and in 4th gear, rpm is 2000 and duty cycle 13%, therefore an increase in rpm of 11%, and a decrease in duty cycle of 8%.
Meaning, on those relative changes, 5th gear, cruising at 60km/hr would be more fuel efficient?
I should point out, that these numbers are just out of thin air... and I'm assuming fuel pressure doesn't rise, with different load?
I'm also assuming the instrument error margin is constant and linear across the range being measured, for rpm and duty cycle.
Any potential holes you guys can see?
Old 09-26-2010, 09:46 AM   #169 (permalink)
Left Lane Ecodriver
You need to know horsepower (RPM is insufficient) and fuel consumption in real time. The charts we see here could be made with a dyno, an MPGuino, and a datalogger.
http://ecomodder.com/forum/showthrea...ncy-12478.html
Old 01-12-2011, 07:37 AM   #170 (permalink)
90 day: 19.36 mpg (US)
Cummins 235-ISB
