Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 02-21-2012, 12:08 AM   #1 (permalink)
Yet another corovelo
After putzing around with the idea for a couple years I finally got busy and put a coroplast shell on my Catrike Expedtion. Borrowed many other folks' ideas except for the method of separating the front and rear end. Most influenced by the Trike Trek 11 kids though.
The body is done but I still need to build a canopy and probably some fenders to keep the inside a bit drier during rain.
Will upload pix later.
JJ
Old 02-21-2012, 12:16 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
that's a serious trike!!!
I have lived in south Carmichael for 20 yrs. Love hoping on the bike trail at the end of arden way!
I have a crosstrainer.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-21-2012, 12:56 AM   #3 (permalink)
All right, I'll try the picture thing now.
Above is the PVC framework placed around the trike.
This one shows the frame attached to the trike. The gray PVC is 1" schedule 80. The white frame is 1/2" schedule 40. The ID of the 1" is only about a tenth of an inch larger that the OD of the 1/2. Makes a good slip fit.
Here is a side shot of the completed body. Below shows the front end removed from the trike. The bottom two pieces of 1" PVC are pinned in with trailer hitches. The top pieces are tight enough and under enough tension that I didn't need to pin them.
And the final photo is a front view of the more or less completed assembly.
I've been riding it for a couple weeks now. Got out of shape over the winter, but am still riding at about the same speeds as I was last summer. Cruise between 18 and 20 mph, thrash at around 28 to 30 mph. I sxpect that as I return to good shape I should be able to cruise at around 22 to 24 mph by say May of this year.
Thanks for reading.
JJ
The Following 2 Users Say Thank You to jjackstone For This Useful Post:
euromodder (02-23-2012), FXSTi (02-22-2012)
Old 02-21-2012, 01:50 AM   #4 (permalink)
mcrews's Avatar
that's an amaxing use of coroplast and pvc!!!
Very nice job?
that'a a decent clip.
I can do 24-25 on a slope down, probably do 16mph on a flat.
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-21-2012, 09:34 PM   #5 (permalink)
Thanks mcrews,
Like I said. Got the idea from the many people that have posted before. My only real contribution is in the manner the front and rear separate from the mounts. While I've removed the front several times, as of now I still haven't needed to take the back end off. I fully expect a flat tomorrow now that I've said that.
I'm actually in West Sac. I get over to the bike trail fairly regularly. Might catch you there sometime.
JJ
Old 02-22-2012, 01:59 AM   #6 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Pretty impressive...! do you have an estimate on the weight the frame & skin adds?
Old 02-22-2012, 12:40 PM   #7 (permalink)
The additional weight is probably 25 to 30 pounds. There are about 9 sticks of 1/2 inch pvc at 1.6 pounds/stick. 7 to 8 feet of 1 inch and a foot of 1 1/2 inch. I screwed a lot of the fittings in instead of glueing them so I could take the frame apart in reusuable pieces if I ever wanted. Total empty weight is probably 70+ pounds. After thinking about it, I probably could have used 2mm coroplast instead of 4mm to save a bit of weight but I figured the 4mm would last longer.
JJ
Old 02-22-2012, 05:17 PM   #8 (permalink)
NightKnight
Diesel
Thanks JJ...
I do like the design... I was looking to do something similar to my Terratrike Zoomer but I was originally thinking of keeping the front wheels outside the skin... and that didn't look possible because the turned wheels nearly touch the trike frame, not leaving much room for a skin... I hadn't thought of putting the skin completely outside the front wheels. Much better for being seen by others as well!
I'd be interested in seeing how you attach the frame to the trike ... I can sort of make out the front attach point, but can't quite make out the rear attach point(s)... if you have time for additional pics, I certainly would appreciate you posting some more!
Last question for now... how is the sight line over the 'hood'... do you find yourself mis-judging the distance to curbs, other obstacles?
Thank you!
NR
Old 02-22-2012, 05:21 PM   #9 (permalink)
NightKnight
Diesel
Looks like you have another velo skin hiding in the garage... ?
Old 02-22-2012, 08:30 PM   #10 (permalink)
This should help with the rear attachment.
I attached 1 inch pipe to the back of the seat braces and to the side of the rack. You can see the 1/2" pipe going into the 1" pipe on the right hand side. That 1/2" pipe goes the entire inside length of the 1" pipe and butts up against the T attached to the rear fo the seat(I think it helps with stability). The two lower pieces of the 1/2" pvc slide into the lower frame mounts near the middle of the trike. They can be seen in the split side view photo.
The other shell you see is hopefully going to be a streamliner for Battle Mountain later this year.
JJ
coroplast, velo
