Old 03-28-2016, 06:59 AM   #1 (permalink)
Workstar - '01 Ford Windstar SEL
90 day: 20.12 mpg (US)
2003 Expedition - '03 Ford Expedition
90 day: 14.96 mpg (US)
A/C Timer
Greetings all. In my wifes van and basically every car I own once the a/c is up and running and the interior is cooled it is too cold. The current options are to adjust the temperature which just mixes in heat with the a/c or what i usually do is manually hit the ac button off/on. I think newer cars do cycle the compressor based on the temperature setting but nothing I have does.
So heres my idea. Make some kind of variable circuit that will go in line to the compressor and cycle it on/off based on time. So on 30 sec off 30 sec, on 1 min off 1 min, on 2 min off 2 min, etc.. I would have a knob (variable resistor?) on the dash to adjust the time.
I know a little about circuits and could probably make something if I knew what to get and how to wire it up. Anyone have any thoughts or insight on this?
Old 03-28-2016, 09:03 AM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I'd control the compressor with a thermostat.
AutoSpeed - $25 Temperature Controller and Display!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Xist (03-28-2016)
Old 03-28-2016, 07:55 PM   #3 (permalink)
Damn thats a good idea.
Old 03-30-2016, 07:13 PM   #4 (permalink)
A thermostat seems to be your best option. BTW maybe you could also improve the insulation around the HVAC ducts and put some of those gel pads inside the evaporator box to keep them cooler for a long time after the air-conditioner is switched off.
