Old 07-29-2015, 09:04 PM   #11 (permalink)
Originally Posted by whatmaycome14 View Post
I had both Tercel and a Paseo, and at one time was VERY into the Tercel Online forum. I can tell you from doing many engine and tranny swaps in both cars that the 5-spd from my '92 Paseo was good enough for 130mph top speed with only 150hp (Maybe less). The gearing also was able to provide 55mpg or better when I wanted it.
It would be a VERY easy swap. Direct bold on replacement for the 4spd from the Tercel.
Just my $.02
Man, that's at least 25 cents worth.
regards
mech
Old 07-29-2015, 11:01 PM   #12 (permalink)
thrashbox
Just my $.02
Thank you.
Old 07-30-2015, 03:17 PM   #13 (permalink)
thrashbox
Just my $.02
Should I get the 5 speed stuff from the 5 speed car like the shifter assy or do I only need the shifter ball
Old 07-30-2015, 10:16 PM   #14 (permalink)
In every transmission swap I've seen that involved a different amount of gears, the shifter assembly also had to be changed.
buzzbox (07-31-2015)
Old 07-31-2015, 08:26 AM   #15 (permalink)
The shifter mechanism is the same on the two. The 91 Tercel looks different, but is the same functionally.
The Following User Says Thank You to Daox For This Useful Post:
Old 07-31-2015, 11:43 AM   #16 (permalink)
thrashbox
Five and 4 speeds as well? Im going to the five should I get the shifter? Thanks, Dave
Old 07-31-2015, 11:48 AM   #17 (permalink)
They're all the same.
Old 07-31-2015, 12:11 PM   #18 (permalink)
Are you sure the same 4-speed shifter is going to work properly with the 5-speed transmission?
Old 07-31-2015, 12:33 PM   #19 (permalink)
Yes. I've made a few short shifters for the guys over the years. They're all the same. Its a very simple cable driven setup.
Old 07-31-2015, 12:44 PM   #20 (permalink)
thrashbox
Thanks to all. Im on my way to da junkyard. Great day to all! Dave
