Old 12-24-2009, 02:53 PM   #1 (permalink)
89HF's Avatar
MightyMouse - '89 Honda CRX HF
90 day: 53.61 mpg (US)
CA smog equipment
I happen to live in the last county in California where periodic smog clearance is not required after purchase. Given that good news, I'm considering stripping off some of that junk on my 89 CRX in order to increase milage/performance. Anyone have any suggestions as to the best way to proceed? What should go and what should stay?
Old 12-24-2009, 02:58 PM   #2 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Please leave the smog alone. Work on technique first. That's where you will get the biggest bang for the buck and the most improvement. Check out the 100+ hypermiling tips.
Welcome to the site
"Judge a person by their questions rather than their answers."
Old 12-24-2009, 11:39 PM   #3 (permalink)
89HF's Avatar
Hmmm, I suppose. But what is the difference between a 49 state car and a California car?
Old 12-25-2009, 12:48 AM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Yeah, leave the emissions equipment alone. I get ~70% improvement over EPA with driving technique. I doubt you'll see a 5% improvement from removing smog equipment, and you may not see any at all. I remember the horrible air quality in CA in the 1960s. Don't take any steps in the wrong direction to take us back to that kind of air quality.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 01-12-2010, 12:51 PM   #5 (permalink)
The emissions equipment is there to increase efficiency, reduce combustion temps, and keep A/F ratios at stoichiometric. In some cases you might be able to gain a little peak horsepower, at the cost of drastically reducing FE and drastically increasing emissions. You won't find any easy efficiency gains unless there's something drastically wrong with your car, like a plugged catalyst, or by doing a complete conversion to a lean-burn or stratified-charge system.
Old 01-12-2010, 12:57 PM   #6 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Power but in your honda not much,, You don't haveta pass smog where you live in cali?
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-12-2010, 01:57 PM   #7 (permalink)
I belive you have one extra catalitic converter and oxygen sensor (other 49 have one cat on obd1 cars, and california obd2 cars have 3cats and 3 O2 sensors where as all others have 2 of both. Search google for <<non foulers>>.
Old 01-12-2010, 01:59 PM   #8 (permalink)
Removal of cats will cause your engine run rich- worser mpg.
Old 01-12-2010, 08:31 PM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
You might have a lower temp thermostat and your ECU might be different, other then that it should have the same catalytic converter right up by the exhaust manifold, and the EGR valve might be different but I'm not sure how, other then that, most of if should be the same or pretty close.
with a 2nd generation CRX (HF?) you should do pretty well, make sure you have light weight wheels (HF, VX, HX or honda Insight wheels) good narrow tires, change your tranny fluid! and give the car a full tune up.
Old 01-12-2010, 08:56 PM   #10 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
A quick search implies it's just the ECU. Swapping to a federal ECU may allow you to pick up a few mpg and it would still be legal.
Smog Test Result Comparison cfg83 EcoModding Central 27 08-23-2016 11:37 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
Smog blues....in so cal Nden Off-Topic Tech 6 12-02-2008 03:38 AM
DIY - Learn how to Weld...Basic Steps and Equipment Needed XFi DIY / How-to 18 11-11-2008 12:44 PM
