Old 01-24-2011, 11:04 AM   #1 (permalink)
Novice but learning!
end wash = barge boards = end plates
ok so were changing our cars front wing from this
to this wing
It will be mounted in front of the curved front piece (and without the silly brackets)
My question is regarding end plate design and shape and also end wash, I plan to make the end plates so that the air is helped over and around the front tires.
and also I want to make some 'barge boards' to go roughly as marked below, so that the air goes around the bottom of the body
Anyone got any hints/tips/advice???
Oh and the fire extinguisers will be moved too.
thanks!
Old 01-24-2011, 11:48 AM   #2 (permalink)
VERY rough idea of how it will look.
Old 01-26-2011, 07:02 AM   #3 (permalink)
Anyone?
Old 01-26-2011, 10:53 AM   #4 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
There was a thread on the motorcycle forum here that talked about a disk mounted in front of the bike to reduce drag. I suppose a couple of flat "canards" at the back ends of the winglets would do a similar thing to the front tires??
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 01-26-2011, 12:00 PM   #5 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I would look at top views of f1 cars of the barge bord era. Roughly emulate how they shape the boards around the sidepods. Experimentation will be your best bet.
Don
