Old 03-28-2013, 01:13 PM   #1 (permalink)
blowncopcar's Avatar
Gumby - '97 Geo Metro
90 day: 58.53 mpg (US)
How do I keep my UG on?
I just installed a cut-off switch on my 97 metro per the way it's instructed here, through the fuel injector fuse.... But my UG shuts off when I turn it off. I thought the UG would stay on.... Is there a cut-off procedure where I can keep it on? NOTE: I had to bypass the relay cause the one I bought was bad. Is that the issue?
1997 Geo Metro 1.0L 5speed
Pass mirror deleted
Custom molded front bumper with top grill closed and 50%summer-90%winter bottom grill closed+ lowered lip BUMPER IN PICTURE IS NOT BUMPER NOW
Partial kamback (in progress)
Headlight covers molded into bumper
Rear underbody tray (suspension to bumper)
Windows tinted 35% NOT PICTURED
Old 03-28-2013, 04:11 PM   #2 (permalink)
I've searched and searched but can't find the direct answer
Pass mirror deleted
Old 03-28-2013, 04:36 PM   #3 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
play around with the UG's power on/off options. there is a way to keep the UG on when the ignition is on run its different per car/make/model. Just make sure it turns off when the ignition is off or it could drain the battery in the matter of 48hours
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 03-29-2013, 07:50 AM   #4 (permalink)
Grey - '01 Hyundai Accent GL
90 day: 35.55 mpg (US)
Big Red - '06 Mitsubishi Eclipse GS
90 day: 31.57 mpg (US)
Roller-Skate - '86 Pontiac Fiero
Page 44 of the UG manual have the different power on/off modes, hopefully this will help. It looks like getting it to stay on is the easy part, getting it to turn off may be the trick.
