Old 11-20-2012, 11:30 AM   #1 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
whats your cold start fuel consumption rate per hour?
2.5l engine, im getting about 5 liters per hour or 1.3gph. temprature is around 5'c. warm idle is 0.3gph.
Old 11-20-2012, 12:04 PM   #2 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
It depends how cold..at about freezing and right after startup, mine is showing about .6 gal/hour and when warmed up about .25
Old 11-20-2012, 12:17 PM   #3 (permalink)
ever_green's Avatar
yes 5'c temp for me which is near freezing. worried my cold gph is too high.
Old 02-03-2013, 08:41 AM   #4 (permalink)
Yes I get about 1.5GPH (imp) cold, dropping to 0.3GPH over a few minutes of normal driving or tickover. 2.3L turbo Volvo.
Old 02-16-2013, 05:46 PM   #5 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Mine hits 2.35 gal/hr on a cold start, settles down to 1.8 then 1.6 then 1.3 then eventually gets below 1. Once things are fully warmed up, with the truck in drive at a stoplight, it will even settle down below .5 gal/hr. Best I've seen is .43. 4.7L V8 Dodge.
Old 03-25-2013, 12:17 PM   #6 (permalink)
Excause me for asking a question not related to topic, but how do you guys measure the rate. Does scangauge or ultragauge give you instant reading on even the smallest fuel comsumption?
I am only asking is because I suspect my idle consumption is very very high. I drove up to the ski resort yesterday and on the way back, I coasted all the way down for 7km and I noticed that needled moved even though I only stepped on the gas pedal twice.
And for my car, which is a 2009 accord, no matter what technique I try, I always end up at 19mpg.
Old 03-25-2013, 02:52 PM   #7 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 21.18 mpg (US)
The White Gnat - '99 Suzuki Swift
Team Suzuki
90 day: 51.87 mpg (US)
Yes, the ScanGauge shows the fuel flow. Actually, your car's compterized system uses it, but the ScanGauge picks up the value & then displays it (scroll through the menu items until you find it)
Using the position of the factory fuel gauge needle to try to judge accurate fuel use is pretty much impossible except for rough approximations (example: usually 200 miles before it drops to 1/4, this time 250 miles = probably better than usual fuel economy on that tank), but that's about as close as you're gonna get without actually filling up at the pump and doing the calculation (or having a calibrated ScanGauge.)
Not sure about your car, but on mine, the fuel gauge needle's position will change depending on what kind of slope the car's on. If I was coming down a mountain from a ski resort, I think my needle would read lower.... then when I leveled-off, it would go back up. (or vice-versa - maybe I'm remembering backwards)
But 19 mpg on an Accord? Sounds like something's wrong - it's constantly running rich or something? Does the exhaust smell really strong? like there's un-burned gas in it or something? I'd think it would be hard to get as low as 19 in that thing unless you're hot-rodding around like "Ricky Racer" all the time.
Old 03-25-2013, 06:00 PM   #8 (permalink)
That's the strange thing! I have tried all the techniques I know. P&G, accelerate really really slow, or very brisk, coast in and out of gear, pumped tire all way up to 38PSI.
I can't think of anything now. The rated EPA is 21 in city, I do 100% city but I am very concerned that with all the technique I empoly, it is still below EPA.
Old 03-25-2013, 06:21 PM   #9 (permalink)
EcoModding Smurfer
Smurf's Avatar
Dime - '95 Chevy S10 LS ExtCab RWD
Pickups
90 day: 18.23 mpg (US)
G/A - '96 Pontiac Grand Am
Team Pontiac
90 day: 32.74 mpg (US)
Automatic Accord or manual? If it's a manual and you're only getting 19, something is terribly wrong. Perhaps you could read over the 100+ Hypermiling Tips on the top of the page, then start a thread to help us help you out.
UltraGauge will also do the Gallons Per Hour readout.
Old 03-29-2013, 09:24 AM   #10 (permalink)
I have an MPGuino, fuel flow rate (or fuel use) is a requirement to calculate MPG. MPGuino measures it using injector pulse width with calibration for flow rate and delay.
I get a direct readout of GPH.
AFAIK the scan guages do it less directly typically by measuring the manifold pressure and fuel trim and calculating. It needs less calibration but is less accurate than injector pulse measurent IMO. The accuracy seems enough though for well branded units and working engine managements.
An MPG meter will help you assess your engines condition. The MPGuino is only affected by faulty injectors, and fuel pressure faults, and perhaps voltage, whereas the ODB units require the entire management system to be working properly, and is more a driving aid rather than a diagnostic aid. Although they do tend to give out information if the OBD registers a fault, depending on model.
People who have ODBII usually get the Scanguage, its a finished consumer product, the MPGuino is more a DIY kit affair for older cars.
1995 Volvo 940 SE 2.3 Turbo estate (petrol) Running MPGuino from Dec 2012
Peak flat: 42mpg
Long run average: 37.4mpg (Jan 2013)
Typical average: 24mpg
UK based, gallons are imperial unless otherwise stated
