Old 04-22-2008, 03:27 PM   #1 (permalink)
california civic hx
hey guys im new on this site, and just recently i found out that the califonia model 2000 civic hx that i own does not have lean burn mode because of emission laws in california. does any one know if i could swap the ecu out for a 49 state hx ecu that i could finaly start getting the mpg that the hx is supposed to be getting
Old 04-22-2008, 03:53 PM   #2 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
You may have to use a different O2 sensor as well. I'm not sure.
On the plus side, a Scangauge will be accurate in your case. It can't read lean-burn and over-reports fuel usage in that mode.
Old 04-22-2008, 04:01 PM   #3 (permalink)
it has a five wire o2 sensor.....
Old 04-22-2008, 05:30 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You need both the ecu and the 5 wire from the 49 state model to make the conversion, but you might not pass smog.
Welcome to ecomodder!
Old 04-22-2008, 06:35 PM   #5 (permalink)
so the 5 wire o2 sensor out of the 49 state car is also different than the california car?
Old 04-22-2008, 08:21 PM   #6 (permalink)
Red
Red's Avatar
CA spec HXs should have lean burn and the 5 wire LAFs. They were CA certified
Old 04-22-2008, 08:45 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Red -
That was my impression. My assumption was that the ECU programming would not be as "aggressive" when it comes to lean-burn in order to comply with California emissions.
CarloSW2
American Solar Energy Society
Old 04-23-2008, 10:48 AM   #8 (permalink)
in the honda dealers parts catalog they do show a (KL) meaning califonia spec ecu part number, and a (KA) meaning 49 state ecu part number, so there are two different ecu avaliable. which makes me believe that they are not equal
Old 04-23-2008, 10:50 AM   #9 (permalink)
Angry
maybe my driving is to aggressive:
Old 04-23-2008, 07:17 PM   #10 (permalink)
Driving God
WTFM8's Avatar
Yoko - '97 Honda Civic HX
90 day: 40.04 mpg (US)
Big Red - '91 Honda CB750 Nighthawk
90 day: 46.29 mpg (US)
Fiddy - '01 Honda SR 50 Elite
Last 3: 97.85 mpg (US)
Trolly - '01 Trek 7200 Multitrack Hybrid Road
90 day: 22.14 mpg (US)
My HX is a 49-state model, but from what I can tell there are no physical differences between CARB and other models sold in the US. The ECU may hold the key. If you have a scangauge, does it go to 9999 MPG very often? Mine does this when I hit the throttle sweet spot, so if you don't get this in regular driving, the CPU is probably different.
Lean burn does pollute more while burning less fuel AFAIK, but that probably wouldn't cause you to fail an emissions test... then again...
The Following User Says Thank You to WTFM8 For This Useful Post:
Xhifer (11-14-2011)
Any guesses on '83 Civic mpg? Ryland General Efficiency Discussion 10 10-19-2013 10:28 PM
Civic HX owner, seeking 60 MPG WTFM8 Introductions 14 03-10-2012 01:05 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
part time paper route driver 88 civic. blindsidecustoms Introductions 5 06-14-2008 03:20 AM
WTB: Honda Civic HX Wheels XFi For Sale 2 01-26-2008 07:02 PM
