Old 10-02-2008, 11:59 AM   #11 (permalink)
Anyone given any thought to the Asus EEEpc? They're currently in the $400-$500 range (the smaller one is less, obviously) but will probably be dropping like all other computer stuff. The AC adaptor for them supplies 12V, so you may be able to hard-wire it more easily than one that requires 15V... Plus it's a little tiny thing!
-soD
Old 10-02-2008, 01:22 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
some_other_dave -
Ab-so-moot-lee have thought about the Asus, but can't justify the coin. I would like to resurrect one of my old notebooks with a solid state hard drive and go from there.
CarloSW2
American Solar Energy Society
Old 10-02-2008, 03:09 PM   #13 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
a note about things that run on 12volt bricks; they are designed to operate on regulated 12v NOT automotive 12v which fluctuates widley and typically contains alternator noise. Some things work well; others do not
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 10-02-2008, 08:37 PM   #14 (permalink)
Granted, that. I figured you'd have a pretty stout filter on the power supply. I'm not familiar enough with the technology to know if that would be much more compact/cheaper/efficient than a DC/DC voltage step-up gizmo or not. I'm guessing that it would be, but it is just a guess.
-soD
Old 11-20-2008, 12:31 AM   #15 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Chevy (Daewoo) Aveo5 SV
90 day: 30.55 mpg (US)
i have a carputer in my aveo. its a great thing to have. ultimate computer nerdness
my 98 Blazer. traded it for the horribly geared Aveo5.
http://www.mp3car.com/vbulletin/show...-b-eby701.html
system transplanted into the Aveo when i traded the Blazer.
http://www.mp3car.com/vbulletin/show...ml#post1247808
that lilliput is a budget screen. never never never use the auto adjust button. you will burn out the resolution its set it. or maybe its the 800x600. thats what mine was set at and i lost it.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 11-20-2008, 12:40 AM   #16 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
as far as having another monitor, most laptops have a secondary output... remove the primary monitor, after setting the computer up to display to an external monitor, then connect a VGABox (google: VGA BOX) to the computer, and you can use a standard RCA jack after that, which means that any in-car DVD player will accept the signal. It's basically converting the signal from computer-ese to NTSC (or PAL) that will be the hardest part.
BTW, if you only want in-car MP3, you can do it w/o a head unit.. you just need an amp and a equalizer...
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 11-20-2008, 12:42 AM   #17 (permalink)
i suggest looking at MP3Car.com - Powered by vBulletin for any questions you may have. best place to get every bit of info you need. like this forum.
Old 11-20-2008, 02:08 PM   #18 (permalink)
Taurus - '99 Ford Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Ford Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Kawasaki Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 Suzuki SX4 Technology AWD
90 day: 24.62 mpg (US)
check out mini-itx.com - news
Old 11-20-2008, 05:49 PM   #19 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Dang, thanks guys! A lot of info and really love the install on the Blazer (great stuff is great stuff)
Old 11-20-2008, 06:38 PM   #20 (permalink)
thanks
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Ford Aveo computer change Rpm shift? wally DIY / How-to 5 07-27-2008 12:16 AM
What we are doing at home : electricity (light, computer...) and water groar Saving@Home 8 07-09-2008 03:32 AM
eBay: Zemco FE computer for carb'd cars (not mine) AndrewJ For Sale 1 06-18-2008 12:47 PM
Metro computer swap? daedalusdd DIY / How-to 4 02-18-2008 06:45 PM
