Old 10-07-2008, 07:14 PM   #1 (permalink)
Camper battery tips
Hey all - on a site I work on a user asked a question that I have no idea how to answer about how to do some customizations on his truck for using solar panels and potentially a microturbine.
I thought this crew might be able to help - thanks all! See you around the forum.
Forum Thread question from the Green Home Huddle
Old 10-07-2008, 08:21 PM   #2 (permalink)
Add a new electrical service panel (or disconnect box) before the existing service panel. (Remove the jumper from neutral to ground in the existing panel.) Wire a contactor between the new and old panels, with the coil and normally open contacts connected to the power from the new panel. Wire the common contacts to the old panel and the normally closed contacts to the inverter. The charger connects to the new panel before the relay.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-07-2008, 09:08 PM   #3 (permalink)
Thanks! I posted your response and a link over to here so he can follow up directly. Really appreciate the help.
Old 10-07-2008, 11:13 PM   #4 (permalink)
Also, replace those very inefficient lights with 12v CCFLs. They cost about $10 or so and are commonly available at computer stores. (Such lights are commonly used in "show off" systems.)
cheap, light-weight EV battery? eta Fossil Fuel Free 5 05-15-2009 01:00 AM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
"Sonata" Lithium Ion battery NeilBlanchard General Efficiency Discussion 0 09-08-2008 03:19 PM
Battery Jumper Alt use? WaxyChicken Off-Topic Tech 5 04-06-2008 01:26 AM
Split battery power apgrok1 EcoModding Central 3 03-13-2008 09:59 PM
