Old 09-04-2010, 12:42 PM   #1 (permalink)
Can a wide band O2 sensor be tested?
How does one test a wide band o2 sensor without hooking it up to a controller? Is it possible with a dvm? From what I've read it looks like it is not possible without an oscilloscope. Is this true?
Old 09-04-2010, 08:16 PM   #2 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I don't believe that a DMM will be fast enough to capture the voltage as it rises and falls according to the sensor reacting to the hydrocarbons in the exhaust flow. Keep in mind that this changes rather rapidly in a second. What are you trying to achieve?
Old 09-04-2010, 08:57 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Google Image Search says you probably don't need a 'scope for a wideband: Oxygen (O2) Sensor – Narrowband vs Wideband Boost Source
Tap in to the correct wire at the ECU, drive until warm, vary the AFR with your right foot, and let us know what happens.
Old 09-05-2010, 12:02 AM   #4 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
no or yes , depends
can not be done
do you mean AFR sensor ? even a scope can not be used .
How 5-Wire Sensors Work (Tech Edge)
with a scan tool testing an OBD2 system ...
you can follow STFT , or EQ ratio graph it if you can . STFT or Eq ratio should swing around 3 to 5 % and center on zero .
quick test is to see if STFT will settle on zero during a steady state . if no
almost always the AFR sensor is skewed or biased high or low , but an exhaust leak upstream of the AFR sensor OR after the cat or a fraked rear 02 sensor can cause rear trim to influence STFT .
an aftermarket AFR sensor in your hand
can not be tested .
the heater resistance can be tested and compared to a specification
but , that is about it .
resistance testing is about as useless as mudflaps on a sledgehammer
Old 09-05-2010, 06:04 PM   #5 (permalink)
Originally Posted by mwebb View Post
can not be done
can not be tested .
That's what I thought. There is a flow chart in the vx service manual where one of the results is replace LAF sensor, but that is in a chassis.
Old 09-06-2010, 12:27 PM   #6 (permalink)
mwebb's Avatar
Snapon MT2500 / Solus or OTC Genesis with OBD1 Honda
many repair shops and many individual independent Techs
have
Snapon MT2500 / Solus or OTC Genesis with OBD1 Honda software
that software will show some type of PID for fuel trim in Live data
the fuel trim should change rapidly about +/- 3 to 5% and it should center the bounce on zero fuel trim adjustment
at 2000rpm hot in neutral all accessories turned off .
for any early 90s honda .
