Old 04-15-2010, 11:35 AM   #1 (permalink)
Throttle Body Spacers
Has anyone had experience or luck with a throttle body spacer on their FI?
I am new to this 'hobby' and bloggin.
I get avg 48 mpg on a 2001 Civic.
Old 04-18-2010, 10:30 AM   #2 (permalink)
5.4L Econo Box
Jim Allen's Avatar
Plugger - '05 Ford F-150HD 4x4 XL
Tried a couple and no gain either on the MPG front on power via a dyno test. A small gain may show up on an engine dyno, but I did not see it on the one engine I had on an engine dyno. Have read they MAY be a little more effective in very specific EFI designs, particularly those with small plenum volumes. One that I tried was on a V8 (chassis dyno), the other a large displacement inline six (on an engine dyno). They also may be more effective on the old throttle body EFI systems. Spend your money elsewhere is my advice.
Jim Allen
The Frugal Four Wheeler and Farmer
My ultimate goal is not necessarily the highest mpg but to make my trucks more efficient configured as I need them.
Old Reliable '86 Ford F-250HD 4x4, 6.9L diesel
Red '00 Honda Accord Coupe, 3.0L V6, automatic
The Plugger '05 Ford F-150HD 4x4, Regular Cab, 8-ft bed, 8,200# GVW, 5.4L V8, automatic, 4.10:1 ratios, 285/70R-17D tires
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
DIY Throttle Body Spacer Coyote X DIY / How-to 51 09-13-2013 06:43 PM
Steel screw broken off in aluminium throttle body RobertSmalls Off-Topic Tech 11 12-19-2009 10:01 PM
Big Bore throttle body for MPG? cfg83 EcoModding Central 19 12-31-2008 09:44 PM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
