Originally Posted by jamesqf
Isn't it supposed to catch evaporating fuel vapors when the engine is off, and store them so they can be sucked into the engine and burned when it's running? So wouldn't you expect some small decrease in fuel economy if you removed it?
I'd say pull it out, find the leak (if it's not in the hoses), and use some glue/sealant to plug it.
it decreases it dramatically, and if you find one line going back to the tank, there is even a danger to remove it...hot days and expansion keep happening while car is off, creating a pressurized system, the canister alleviates it. there is an upper atmosphere and a lower one in all vehicles, even the spot of the canister is einsteined, do not put it someplace else. also, check to see of one of the lines goes to thermal vacuum valve rather than straight to intake, and check vacuum pressure, you may be overdoing it with an error, canisters normally do not ask for much, it is a safety for the safety and for emissions that do not hinder, it can even add to power (utilizes system venting). Another note is the neutralizer of charcoal, the lines last forever with it, primitive air dryer, or whatever it is.
