Old 08-21-2009, 02:18 AM   #1 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Noisy rear end problem in the Previa.
And it's not the beans...
The Previa has a rear end issue. I found a possible solution on the net with a loose pinion nut but I tightened it up and I'm still getting the roaring noise especially at highway speeds. I replaced the end seal at the same time because it was leaking badly. I wonder if it could just be the pinion bearing. I can feel a roughness when I rotate it by hand. It's so loud I'm beginning to worry about my hearing. I'm contemplating replacing the pumpkin. I guess I should try to get a peek at the gears to see if I can see any damage. I know the sound and feeling of a bad bearing and it seems to be similar but it could be the diff, I suppose. Is there any way to be sure without dropping the whole thing? Can a bad diff cause poor FE?
The good news is I found a rear drum dragging which I loosened up so that should help with the FE.
Hope your vehicles are running smooth.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 08-21-2009, 07:18 PM   #2 (permalink)
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
It sounds to me like the bearing is already shot. The chances are pretty high that if the bearing is pitted, which is what it sounds like, it probably also has metal in the fluid, which in turn just chews the gears up, which is a downhill slide.
I'd look into getting a whole used rear end and just replace the whole thing. Generally, unless they get low on oil, they run, relatively, forever. I'd put new gear oil in, when you swap it.
The Following User Says Thank You to Whoops For This Useful Post:
orange4boy (09-03-2009)
Old 08-24-2009, 05:56 AM   #3 (permalink)
blueflame's Avatar
Try filling it with moreys additive but it sounds as if it got run dry
Old 08-26-2009, 04:28 AM   #4 (permalink)
My money is on the pinion bearing. I'd replace the bearing, use a new seal, clean up the innerds, and add new synthetic oil. Unless when you are in there you see a major problem, you might be able to eek out another 100,000 miles or so.
The Following User Says Thank You to bikin' Ed For This Useful Post:
Old 09-03-2009, 04:19 AM   #5 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
Thanks for the help.
I had a hunch it was the bearing. I've had a similar bearing issue on a belt sander that sounded similar. Next job: pinion bearing. If that does not fix it the pumpkin is next.
I don't think I ran it dry. It was 1/2 pint low at most.
Video: clever, simple demo of teardrop shape -pointy end first vs. blunt end first MetroMPG Aerodynamics 12 11-21-2015 04:04 PM
Interest in rear wheel power (electric) bwilson4web General Efficiency Discussion 15 01-23-2011 03:41 PM
Rear Alignment: Drivability vs Economy Southcross EcoModding Central 11 04-22-2009 09:40 PM
New steering system concept to minimize aerodynamic drag Blue Bomber Man Aerodynamics 37 03-24-2009 02:19 AM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
