Old 10-02-2014, 05:42 AM   #11 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by niky View Post
You'd be better off doing a partial grill block... especially seeing as how the Mustang's grille and hood form a gigantic parachute...
I agree here for sure ! An upper grille block would do so much more to improve the aero.
Here are the ways that it has been done on land speed cars :
Old 10-02-2014, 04:47 PM   #12 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I did a little CFD work in a amateur grade program on your car, but still came up with some interesting results when i blocked the bumper 'pocket' on one side and left the other stock.
Apparently, there is some 'aircurtain' effect going on. ( Note the pressure difference in the front of the tire on the unblocked side.
On a side note, i got the approximate Cd down to .28 by blocking the upper grille flush and closing off 3/4 of the bottom.
This is the stock side :
And this is the blocked side :
There is more stagnant air on the blocked side ( the dark blue )
The Following User Says Thank You to Cd For This Useful Post:
niky (10-04-2014)
Old 10-03-2014, 07:07 PM   #13 (permalink)
pockets
The pockets are in a very favorable pressure gradient and surrounded by large radii also within a favorable pressure regime.
I suspect that they make little difference to the air.Just little pools of dead air with active flow skimming over.
