Old 01-23-2010, 03:31 PM   #1 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Found a very useful graph of tire radius vs inflation pressure for anyone interested in correction factors for tires.
Like me... I just went from the stock size/pressure of 175 65 14 @42psi to 185 65 14 @ 51 psi. I found the revs per mile but not with pressure compensation.
1.5mm change in RR between 35 and 50 psi that works out to:
1737.99mm Dia @ 35
1747.41mm Dia @ 50
difference is .5% rolling diameter. meh.
Original tires Bridgestone RE92 175 65 14 xl: 902 rev/mile
New tires: Nokian WR g2 185 65 14 xl: 884 rev/mile
2% correction for tire size and .5% for pressure= 2.5% total correction.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
"Inflation pressure does not affect grip": Autospeed article. orange4boy EcoModding Central 158 05-06-2010 03:29 PM
